where do you run your power wire?
Old Jul 7, 2006 | 08:49 PM
05-RS1's Avatar
Default where do you run your power wire?
how did everyone run their power wire from the battery to the amp?
Old Jul 7, 2006 | 08:54 PM
SquallLHeart's Avatar
thru the firewall and routed back to the trunk (where most people have their amp)
Old Jul 7, 2006 | 08:57 PM
Rob_Tampa's Avatar
There is a grommet in the firewall that is about 10 inches over the where the steering shaft passes through. Its alot easier to find it from the inside. I poked a long screwdriver through so I could find it from the outside and fed my cable through. Also take a look in the tech section for how to disassemble you interior.
Old Jul 7, 2006 | 10:07 PM
fujitech43's Avatar
If you have a automatic you can run it on the driver side but if you have a stick then the clutch will be in the way and you have to bring it over on the passenger side.
Old Jul 7, 2006 | 10:09 PM
05-RS1's Avatar
ok thanks guys! i found the grommet and fed it through there. ran it underneath the driver side door seal, under the carpet, under the back seat, and out the trunk. thanks again for the help
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
missing_image
Feb 7, 2015 07:18 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
ScionRo
Jan 2, 2015 07:54 PM
randode
44
Jun 29, 2004 04:19 PM
