I need a high flow cat for my Megan Exhaust!
When I had my Megan cat-back exhaust put on, they had to cut behing the stock exhaust and weld the echaust on. I am now going to go with the megan header and megan s-pipe, and I don't want it to be restricted by the stock exhaust cat. Can somebody please help?
Originally Posted by filmnews
I wnet to every shop in town, and they all said that they could not remove the cat because it was illegal.
you should have just bolt it on yourself and save the OE pipes when needed.
well if you get a high flow cat make sure it will pass emissions on your car, just becase you have a cat on it, doesn't make it legal. you should go with the header but dont' hack anything up and put your stock one back on for smog, i don't know how strict they are where you live but in cali. if you have a header your are NOT going to pass smog, even a HF cat might not pass because technically you modified the factory emissions system which is a no no.
just remember from now on, never hack up your exhaust system for any reason, thats what bolt-on's are for.
haha.. i live in cali and i dont worry about smog at all.
i hacked up my stock midpipe, but thast because i can roll down to a smog shop in pomona, slide the guy a hundred, and he will pass me.. without even looking at the car.
gotta love the ghetto
Guest
Posts: n/a
If I decide to go with the Megan header and S-pipe, do you think that runnung the stock cat will effect performance?
i live in maryland. the emissions are tested on obd2 cars by just plugging in a code scanner to the ecu. as long as you have no check engine light and the ecu has enough memory code stored you pass. they take a mirror around the vehicle but you could still get away with just putting in a straight pipe then putting the heat shield from a cat around it to make it look like you have one.
when i do my full exhaust eventually i'm going to put in high flow cats. i'm going to use random technology cats. they make the highest flowing aftermarket cats. i had a magna flow on my truck and i will never by one again. it wasn't on my truck for a year and the guts broke and turned sideways inside the cat. i had to buy another cat again.
