Ksport owners HELP ME!
Old Jul 10, 2006 | 04:39 PM
metal112524's Avatar
Default Ksport owners HELP ME!
Ok guys ive already done a search and found some Ksport sales on here but untill today i have never heard of them but the discription makes these babies sound like the M.O.A coilovers. As I am a noob in suspension can someone fill me in on a nice coilover tech thread also.
They offer a
• Drop: 0"- 4"
• Spring Rates: Front 6/336 Rear 3/168
• 36-Way Adjustable dampening
• Adjustable spring perch for height adjustment
• Adjustable body allowing maximum suspension travel
• Pillow Ball Top Mount w/ Adjustable Camber
• Monotube high pressure design
• One Year Limited Warranty
Whats the deal??? Ride info, does it do all it says it can do and does it do it well???
Old Jul 10, 2006 | 04:48 PM
illiST's Avatar
They are designed for motorsports use.
Pillow Ball = more harsh ride
Spring Rate of 6 in the front = more harsh ride
If you are looking for comfort.. this is NOT it. If you are looking to do some hot laps in your xB.. well here you go. Otherwise, expect you teeth to rattle a bit.
Good luck
Old Jul 10, 2006 | 05:23 PM
TXboxdriver's Avatar
anything more than 4.5kg/mm front and u need slicks to get the full benefit for our weight of car
the 3kg/mm rear is ok...wonder why the front is so stiff??
Old Jul 10, 2006 | 05:37 PM
dugzilla's Avatar
you can buy a softer spring rate for the front if you want. PM honeyobucket he has a set on his box.
Old Jul 10, 2006 | 05:38 PM
hayalex6's Avatar
These are just like the D2's, just cheaper.
Old Jul 10, 2006 | 06:01 PM
so these are for autox or something does ksport make any "crusin" worthy coilovers?
Old Jul 10, 2006 | 09:23 PM
illiST's Avatar
Old Jul 11, 2006 | 12:58 AM
BrianxB's Avatar
WAY too stiff of a spring rate for the front. These are a copy of D2 coilovers. You should just run D2s if you want something like this, the set I have has a 4kg spring in the front and rides stiff. I couldnt imagine a 6kg spring in there.
My D2's will be for sale soon if you are interested.
Old Oct 31, 2006 | 04:38 AM
egg2box's Avatar
My Ksports went on this past weekend. Ride amazing.
Old Oct 31, 2006 | 04:50 AM
hotbox05's Avatar
my car rides like total poo but it handles like it's the king of teh road.
Old Nov 2, 2006 | 06:55 PM
honey0bucket's Avatar
alright i've had these on my box for a few months now and im dropped to the MAX.
if you want comfort. do not..i repeat DO NOT GET THESE!!!!
this are straight up performance at its finest. they are stiff as you can imagine. you will hold the road untill traction control applies the brakes for you (which is very annoying...someone tell me how to disable it please!)
they are an ease to install and an ease to use. anyother questions ask away.
Old Nov 2, 2006 | 10:19 PM
hotbox05's Avatar
dropped to teh max the front lip would be on or below the ground, that's if you had like 14's with lo pros so as to not have tire interferrence issues
Old Nov 2, 2006 | 10:20 PM
hotbox05's Avatar
get grippier tires and it'll happen less often
Old Nov 2, 2006 | 10:24 PM
yeah but still...it happens going around corners and not so high speeds...its so annyoying.
Old Nov 3, 2006 | 07:55 AM
hotbox05's Avatar
hmm i don't have that problem with my car....
Old Nov 3, 2006 | 02:32 PM
jomo's Avatar
It doesn't appear that your XB has a balanced setup. Super stiff front springs reduce roll like adding a front sway bar. If you don't balance this stiff front out with a rear sway bar, camber, or other understeer reducing technique, the car will loose front end grip.
Old Nov 3, 2006 | 02:49 PM
im on the stock wheels..and when im on flat surface and i turn my wheels to the left or to the right...i cannot even fit a credit card inbetween the wheel and the fender...cant go any lower than that...
but the thing is...i still have plenty of grip....i can accelerate through the turn and while im accelerating T/C starts beeping at me and then ultimately slows me down. my tires arnt even squeeling yet.
i havn't got around to getting a rear sway bar yet only because i really dont care until i actually have wheels :-p
Old Nov 3, 2006 | 03:07 PM
jomo's Avatar
Actually a good time to balance your car is with lousy tires. You can feel very easily where you are loosing grip at much lower, safer speeds. After getting the car balanced, you should be all the better with grippy tires. Of course the different tires/wheels may require small adjustments, but not much.
You don't want to find out you have a lot of oversteer with grippy tires. You may find yourself in a ditch.
Old Nov 3, 2006 | 09:04 PM
BrianxB's Avatar
Me neither.
25 mph exit ramps = 70mph worth of fun.
Old Nov 3, 2006 | 09:16 PM
i think i just need wheels and tires....sigh..after the turbo i supose
