Need some help!!!!!
Old Jul 11, 2006 | 12:14 AM
erodsani's Avatar
Default Need some help!!!!!
I tried doing a search, but my parents computer is slow as hell. I am in the process of taking the tape off of the B column on my 06 xB and there are a few reminants by the small rear door windows that I can't get out. Everything else came off great, just a few little peices that I can't get to. Is there a link to the DIY or does someone have a quick tip? I could really use the help, thanks in advance.
Old Jul 11, 2006 | 12:16 AM
Max's Avatar
Max
Heat gun or direct sun and a hot day.
Old Jul 11, 2006 | 01:16 AM
erodsani's Avatar
Well, I got one side off. I had to pry the rubber back with flathead screwdriverand I got ahold of the sticker and got it all out. Passanger side is all done. The driver side still has some over the little plastic window in the rear door, but I'm going to try to get it off tomorrow night, then wax it. Thanks for the info.
Old Jul 11, 2006 | 03:12 PM
erodsani's Avatar
So is there any easy way to get the rubber trim off or pull the small window out in the rear doors? There is some tape left in there that I can't get out and I am getting closer and closer to scratching the paint each time I try. Any help would be appreciated. Thanks.
Old Jul 11, 2006 | 03:18 PM
D_M_A_N's Avatar
Instead of using a metal screw driver, I would go to the hardware store and get a plastic scraper. Fingernails work too! :D But if you cant reach it, use something plastic not metal.
Heat gun will help, hot day in the sun.
If it leaves glue, get some mineral spirits, or acetone.
Old Jul 11, 2006 | 04:46 PM
erodsani's Avatar
My fingernails hurt so bad today from doing this last night! Yeah, I swithced to a plastic screwdriver. I just need to get behind that rubber that holds in the (just found out yesterday!!) plastic window. No easy way to get that out?
