DIY: Rear windshield nozzle SUPER SOAKER!
Well, since I've taken off my rear wiper, I have no need for this rear wiper nozzle, so I decided to do this:
- Open the hatch, you will see a black plastic cover over the third brake light.
-pull straight down, and the cover will come off, exposing 2 10mm screws. once the screws are taken out, pull off the 3rd brake light, and undo the wiring harness.
-you will now see your washer nozzle, with a rubber hose going to it. (NOTE: My rubber hose is going the opposite way of yours, because I already flipped it!)
-with a finger on one side, and a flathead screwdriver on the other, push in 2 tabs, and PUSH the nozzle to the outside
-then flip the nozzle around, so the outlets are pointing up, and push the nozzle back in the hole, making sure the tabs re-engaged
-make sure the rubber hose is not kinked
-reattach the brake light, and the cover, then proceed to spray people lol.
NOTE: I did this on my friends ride yesterday, he has a 2006.5, while mine's a 2006. His rear nozzle has 2 outlets, so it sprays both ways. While mine has a single outlet.
The nozzles are adjustable. Just take a safety pin, and move the outlet around.
ive been thinking of doing this for a while now. great how-to!
now i gotta find a way to put my front nozzles in my fender since i have the CF hood without holes.
you'll be sorry if you're tailgating me now!!!
Yea, thats what i meant...the wind takes care of it...you don't need timing, depending one speed and how close you are...when you squirt, the wind should push it straight to the car behind you...
