How do I remove my stock tailights?
Old Jul 14, 2006 | 07:49 PM
Archngl's Avatar
Default How do I remove my stock tailights?
I completely removed the rear bumber, and could NOT figure out how to get em out...
HELP!
Old Jul 14, 2006 | 08:02 PM
Big_Kokujin's Avatar
OMG,
There are 2 10mm on the inside...you have to open the grills with the tabs on the inside by the speaker grill. use an elbow joint and an extension...also push against from the outside as you loosen the 10mm nuts...
Old Jul 14, 2006 | 08:05 PM
RMS's Avatar
RMS
Default Re: How do I remove my stock tailights?
This is a joke right?
Old Jul 14, 2006 | 08:12 PM
Archngl's Avatar
I saw the grill cover... I opened it, but I couldn't see what I was supposed to do.... Anybody have a pic to help out
And no RMS... not a joke... sorry.
(I'm slightly retarded)
Old Jul 14, 2006 | 08:15 PM
Okay you can do it this way then. But its much more time cosuming...
There are some allen-heads on the top that the cargo net hooks are held with. take them off. take off the black piece of trim thats around the hatch latch. then you can just fold it back some and you will be able to see them.
Old Jul 14, 2006 | 08:17 PM
Archngl's Avatar
That makes alot of sense.
Cause with my luck I'd drop a bolt in there anyway! lol
Old Jul 14, 2006 | 08:22 PM
RMS's Avatar
RMS
Sorry, couldn't resist.
There is a small access panel on each side, remove this panel. Now you can get to the 2 10mm nuts. Disconnect the connector for the wiring and that is it.
Old Jul 14, 2006 | 08:28 PM
Its not too far down
Old Jul 14, 2006 | 09:56 PM
bb05's Avatar
dude you just got to feels around.its alittle to easy,you dont have to dismantel you car. it will take you like 2 seconds to feel for them and like 1 minute to take them off. pretty easy.and if they fall there is cushion on the bottom,just reach down there and get them.
Old Jul 14, 2006 | 10:00 PM
ElChupacabra's Avatar
Sledgehammer...
Old Jul 14, 2006 | 10:17 PM
Archngl's Avatar
listen scion joe... I've had enough of your lip,
...I like the stock one better!
Old Jul 14, 2006 | 10:19 PM
Dont worry, the first time I tried to take out my tails I couldnt figure it out right away either. Once I did figure it out I dropped the nuts down into the side panel. They were a total biotch to get outta there. I see your concerns...
Old Jul 14, 2006 | 10:30 PM
RMS's Avatar
RMS
Just have a magnet on a stick at the ready.
Old Jul 14, 2006 | 10:32 PM
True, forget about the metal wheel well
Old Jul 14, 2006 | 10:36 PM
RMS's Avatar
RMS
You have to have skills!
Old Jul 15, 2006 | 08:21 AM
chiburu's Avatar
look up 1epoxybox posts. he has a step by step guide with pics. very informative. helped me to do my own LED tails.
Old Jul 23, 2006 | 08:43 AM
Loneriver's Avatar
Go to TRDSPARKS.com and search for the Euro taillight. There is a link to pdf instructions.
http://www.trdsparks.com/displaypart...4&parts_id=388
Old Jul 23, 2006 | 09:05 AM
punksterz626's Avatar
took me awhile to find out how to remove the rear tail light as well so i understand where you coming from. there are 2 10mm bolts that hold up the light. Just remove the plastic cover first. Feel where the 2 bolts are at just unscrew those with your socket and your set. Good luck
SloTC1
Apr 2, 2015 07:11 PM
DerekMarq
Jan 27, 2015 02:38 PM
minter66
Dec 15, 2014 01:45 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
