mrgeorgegarcia
07-02-2004, 08:40 PM
I GOT SOME 20 INCH TIS 03 WHEELS WITH 225/30/20 TIRES
AND IM Getting the rubbing in the front when wheel lock left or right
any suggestions to get these to fit?
i have goldline 2 inch lowering springs....help..... :cry: :cry: :cry:
rolex87
07-02-2004, 09:16 PM
Is it rubbing on metal or the plastic splashguard?
Mike R.
rolex87
mrgeorgegarcia
07-03-2004, 12:34 AM
its rubbing on the metal tow ring on the inside when you turn left and rubbing on the metal inside when you turn right and also it rubs the plastic splash guard which is not a big deal i could fix that.
Munch
07-03-2004, 01:37 AM
You got some pics :?: :?: :?:
DJ_X_Trodinaire
07-05-2004, 09:47 PM
Get smaller wheels? :idea:
autosound
07-05-2004, 09:54 PM
I have 20" foose speedsters with the same tires on mine we took out the inner fenderwells and rolled the entire fender one edge to the other. and last took a air hammer to the metal in the inside to smooth it out. and even with all of that there is still a little bit of rubbing, im running eibach springs which have also been cut............. in the rear i have a system so it actually sits down a little lower and once again we rolled the fenders from edge to edge. do yourself a favor and look at the right rear wheel if the tire is about .5 inch away from the body kit closest to the rear passenger door roll the fenders all the way around. i didnt do it at first and ended up blowing a tire cause when i hit a pothole the tire actually went forward into the kit, and cut the tire
supwitheddie
07-05-2004, 10:18 PM
I have 20" Axis Reverbs on my Xb and i had to do a lot of modification to get rid of the rubbing. Basically you need a big hammer, and something to cut the plastic liner with.
I got all of the rubbing out except for the rear when I have lots of weight in the back. There is a little peice of metal on the inside of the tire and rubs, and needs to be hit back a little bit more.
I am running spacers in the rear, Nitto 555 225/35/20's all the way around, and am still at stock height.
phatfront
07-19-2004, 01:31 PM
what size spacer are you running with the Axis?
5mm?
