215/150/17 OK?
Old Jul 19, 2006 | 03:16 PM
Raziemlutto1's Avatar
Default 215/150/17 OK?
So i have a blown tire on my set of 17"s and i need to replace it... The used tire store only has 215/50/17... would that fit my car?
Old Jul 19, 2006 | 03:38 PM
RTon20s's Avatar
215/50/17 is HUGE. Diameter on those is 25.46". Stock diameter is only 23.74". You will be much better off with 215/40/17. Diameter on those is 23.77" Pretty much as close as you can get to stock diameter on a 17" wheel.
If you absolutely must have a larger side wall, look into a 205/45/17.
Old Jul 20, 2006 | 09:06 PM
Dwestxb's Avatar
If you are only replacing 1 tire you need to get the SAME size as the other 3, or your car won't drive correctly.
