Black Headlights for the XB
Old Jul 21, 2006 | 10:37 PM
m4ng0's Avatar
Default Black Headlights for the XB
I was wondering if anyone know's of blacked out headlights like the mazda3 are made for the XB I found projector-like headlights on ebay but im looking for a more OEM look-a-like but black
Old Jul 21, 2006 | 11:00 PM
dekthai's Avatar
https://www.scionlife.com/forums/vie...=43569&start=0
Old Jul 21, 2006 | 11:02 PM
stick_1NZ's Avatar
Some have done the oven method to blacken out their OEM headlights.
Here's the DIY I followed when I did my black housing:
To seperate the headlights, I preheated an oven to 300 degrees and placed the headlight on a baking sheet with some aluminum foil. (Don't want to upset mom for using her baking sheets for car plastic, now do we?) After about 5 minutes you could pry the housing apart using a flat head screwdriver. Some parts of the housing are a little fragile so don't be too rough. There is a reinforced area on the bottom, about 2 inches in from the inside corner that I could torque on pretty hard and not crack anything.
Now comes the taping off. You'll probably need to rig up something from what you have laying around the house. I had one of those lint rollers that is basically a wide strip of masking tape. I rolled it on my shirt to pick up some lint and make it a little less sticky. I tried using stronger tape and where it touched the side, it ended up pulling off the chrome. Luckily it was an area I was going to paint, but be careful when you do this. I masked off all the areas that I figured were involved in focusing the light. I also masked off the top since nobody will see that it's unpainted. So basically the bottom, front, sides, and the low beam cap got painted. You can see this in the photos above.
To reassemble the headlights you can optionally run a thin bead of silicone sealant to make sure you have a good seal. I skipped that and pushed the housings together as thight as I could. Put them in the oven, same as before, and after five minutes you could push them together and they'll be properly seated. Snap the 4 little metal clips you took off before to help hold the housing together while it cools. Then just reassemble everything in the reverse of how you took it off. I suggest leaving off the two button/screw fasteners under each headlight off, in case you want to take the bumper off again in the future.
The paint I used was black BBQ paint. $3.99 from the local AutoZone. It can withstand temps up to 1000 degrees, and drys quickly to a beautiful satin black finish.
Link for the full write up:
http://cryogen97.net/howto/blackhousing.html
Old Jul 22, 2006 | 12:31 AM
m4ng0's Avatar
awesome thanks
Inazuma
20
May 3, 2023 01:58 AM
mischman
Mar 31, 2015 03:16 AM
stenger
Mar 29, 2015 08:03 AM
umnitza
Dec 1, 2014 06:26 PM
