question of short shifter
Old Jul 24, 2006 | 06:25 PM
infinity20k's Avatar
Default question of short shifter
ok how in the world do you get that little black pices off on the right hand side that is holding the pin in place. a drill wont go threw it and i get jimmy that damn thing off and thing
Old Jul 24, 2006 | 06:30 PM
GammaTNT's Avatar
i hammer a flat screwdriver in to get it out.
i scruff it up a bit.
Old Jul 24, 2006 | 08:18 PM
brian's Avatar
dremel works, i think i used a chisel
Old Jul 24, 2006 | 09:27 PM
thanks guys
Old Jul 24, 2006 | 10:40 PM
porkipine69's Avatar
we used a dremel, that piece is a pain!
Old Jul 25, 2006 | 02:49 AM
vanberge's Avatar
<------ also used dremel.
<------ hates lockwashers.
Old Jul 25, 2006 | 04:04 AM
soros151's Avatar
Used the screwdriver and hammer method... pain in the @ss,
<----------Also hates lockwashers
Old Jul 25, 2006 | 04:51 AM
xnevergiveinx's Avatar
i used a dremel, came off so easily that way...
the hard part is the plastic collar on top...i cracked the housing getting that off and said every swear word imaginable for the 20 mins i was prying away at it
Old Jul 25, 2006 | 05:57 AM
Control_Are's Avatar
"Screwdriver and hammer" method for me as well. It was a PITA but I eventually managed to pry that annoying washer off. If you have access to one, I highly recommend the dremel route. It will make the removal far easier.
Old Aug 1, 2006 | 10:25 PM
TWM_Performance's Avatar
Default Re: question of short shifter
The 2 methods mentioned above work well, but I recommend the Dremel method if you have access.
With a Dremel and cutting disc attachment, I just slice the clip on one side, you'll probably slice the plastic a little too but don't worry. Then, I pry the clip with a sharp flat head screwdriver and it comes off easily.
If you don't have a Dremel and have to use the hammer and screwdriver method, I usually use 2 screwdrivers, one small flat head and one big flat head. I've sharpened the small flat head screwdriver to make the end as sharp as possible, then hammer it in between the clip and the plastic shifter assembly. Using the larger screwdriver, insert it in to the gap created by hammering the small one in and pry around the clip working it off from each side. It may break, but that's good because it comes off easily then. Don't worry if you break it we include a couple of new ones with our Short Shifters.
I hope this helps.
Kevin
TWM Performance
NonStopTuning
Jun 29, 2015 07:42 PM
disaster06
Feb 3, 2015 08:50 PM
disaster06
Dec 26, 2014 03:00 PM
disaster06
Dec 4, 2014 07:05 PM
gularti
Dec 4, 2014 01:21 PM
