Anyone wanna help with a APEX TT install?
Old Jul 25, 2006 | 10:03 PM
yamaha16bw's Avatar
Default Anyone wanna help with a APEX TT install?
OK I need to get my Apex turbo timer hooked up today if I could. I just need to know what wires I need to tap into for the ing. harness. I have a 12v+ constant(red), IG1 output(green), and IG2 output(blue) that I have no idea where they go on the ing. harness. Everything else is hooked up. If someone could help me out here that would be great!!!
Thanks!!!
Old Jul 25, 2006 | 10:34 PM
thisisdudewhoru's Avatar
Team Sci-Tech
Your cars are awesome and have so much stuff on them. Why dont you send some of that money this way so I can make my car as rad as one of yours. I would help you but I havent ever installed one cuz, I have no turbo except on my srt in which I dont have on either.
Old Jul 25, 2006 | 10:47 PM
yamaha16bw's Avatar
Thanks man! Yeah we are a Scion Family...haha. We havent decided on what the RS2 is getting but its looking like a s/c'r just to mix thing up a bit.
Old Jul 26, 2006 | 03:07 AM
yamaha16bw's Avatar
Please help anyone with a turbotimer!
Old Jul 26, 2006 | 03:33 AM
zer0's Avatar
Joe@Dezod should be able to help you.. PM him.
Old Jul 26, 2006 | 03:38 AM
yamaha16bw's Avatar
I have but I think he's really busy. He hasnt gotten back with me in awhile. I know he runs the same Turbo Timer.
Old Jul 26, 2006 | 03:44 AM
zer0's Avatar
Try PMing "jam0321" I believe he was gonna do a DYI..
Old Jul 26, 2006 | 03:47 AM
yamaha16bw's Avatar
ok thanks for the help!
Old Jul 26, 2006 | 01:52 PM
yamaha16bw's Avatar
Anyone got a pic of the wires you tapped into. Thats all I need
Old Jul 26, 2006 | 02:04 PM
ProshopXB's Avatar
12 V constant- Red (factory colors)
Ign1- Blue
Ign2- yellow
You should be able to take of the housing surounding the steering column to access these wires.
Old Jul 26, 2006 | 06:52 PM
BlkSandPrlTurbotC's Avatar
the kid gets like 20pm's a day (no joke ive seen it) plus he just started his job not too long ago so he's never on in the daytime anymore, only at night after work if he's not on then, we're probably at hooters
oy lemme know how it goes, i wanna install one too....
*edit* didnt even see proshop respond w/ the wiring lol. my bad!
Old Jul 26, 2006 | 11:06 PM
yamaha16bw's Avatar
Ign1- Blue
Ign2- yellow
Well awhile back before Joe moved he said something about a yellow wire. I'm going to take the covers off the column and take a look tonight.
Old Jul 26, 2006 | 11:10 PM
ProshopXB's Avatar
Ign1- Blue
Ign2- yellow
Here's alink to all the wire colors, just in case.
Edit** See below
Old Jul 26, 2006 | 11:36 PM
yamaha16bw's Avatar
Anyway you could post it here cause I cant find where to sign up to get a password for that site.
Old Jul 26, 2006 | 11:43 PM
ProshopXB's Avatar
I appoligize for that, it pulls up for me . I will see if I can find a way to post it.
Old Jul 26, 2006 | 11:57 PM
yamaha16bw's Avatar
Cool man thanks a ton!
Old Jul 27, 2006 | 01:38 AM
ProshopXB's Avatar
05 Scion tC- Wire colors
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch
Old Jul 27, 2006 | 02:04 AM
yamaha16bw's Avatar
your the man! Thanks!
Its too dark out for me to try this tonight but I'll do it right after work tomorrow. I'll let you guys know how it works out.
Old Jul 28, 2006 | 09:24 PM
yamaha16bw's Avatar
Ok Turbo timer is in and working. Problem is now my Python alarm wont arm until the engine shuts off. Kinda sticks but I feel like I have to sit in my car or stya near it till it shuts off to engage the alarm. Might as well take the TT off and just let it idle on its own. Anyone else have this problem?
Old Jul 28, 2006 | 10:21 PM
ProshopXB's Avatar
I knew I was gonna have the same problem with my alarm and TT. So I bought a switch so I can shut the Ignition wire from the alarm off and that will allow the alarm to arm while the TT is running. Just an idea if you wanted to try it....
