question about the TRD quick shifter and assembly clutch
Old Jul 26, 2006 | 02:53 PM
Bluntman72's Avatar
Default question about the TRD quick shifter and assembly clutch
I am about to buy a 06 scion XB in the next 2-3 days and I am getting a manual but I was wondering if it is worth spending the extra money on the TRD quick shifter and assembly clutch optional equipment. I have driven an automatic most of my life so this will be my forst standard transmission. I have driven some of my friends cars that have manual but I will have to get used to driving one every day.
currenlty these are the options I am getting
an 06 in black sand pearl with:
rear spoiler
ipod radio upgrade
TRD rear lights
arm rest
vehicle shield protection
floor mats
cargo cover
Old Jul 26, 2006 | 03:16 PM
hayalex6's Avatar
you should not buy the following from the dealer:
Quickshifter
TRD Clutch Assembly (I wouldn't buy this anyways, it's a waste of money)
TYC tail lights
Arm rest
Floor Mats
and skip the cargo cover, it's very flimsy, and most people get rid of theirs.
Old Jul 26, 2006 | 03:23 PM
Bluntman72's Avatar
thanks for the reply, I am probably going to the dealer after work today to sign the paperwork. only reason I was thinking of the cargo cover is that the area I live in is an good neighborhood but it is a transitional neighborhood and there are alot of issues with people trying to take stuff from cars and I have to park in the street so I figured the cargo cover would help conceal anything I had in the back of the car.
Old Jul 26, 2006 | 03:26 PM
hayalex6's Avatar
Well, I never finished my post, my bad.
But avoid the products I listed, because you can find them cheaper online on websites like www.trdsparks.com
Check out the tech section, someone made their own cargo cover. There's also a JDM hard cargo cover, which you can get on www.newscionparts.com
Old Jul 26, 2006 | 03:48 PM
Bluntman72's Avatar
thanks for the websites, I will order some of the other parts from there. is there anything special about the Scion security system, I was just thinking of going to best buy and getting a basic viper alarm system for it.
Old Jul 26, 2006 | 04:01 PM
hayalex6's Avatar
scion securityimo is a waste of money. You would be better off in getting an aftermarket alarm.
Old Jul 26, 2006 | 05:42 PM
Guest
Guest
Posts: n/a
PrecisionMuffler.com has HD clutches for everyday use or high performance.
Click the link below
http://www.precisionmuffler.com/id143.htm
Old Jul 27, 2006 | 11:38 PM
vintage42's Avatar
Default Re: question about the TRD quick shifter and assembly clutch
Originally Posted by Bluntman72
I am about to buy a 06 scion XB...I am getting a manual but I was wondering if it is worth spending the extra money on the TRD quick shifter and assembly clutch optional equipment... this will be my forst standard transmission....
If you have not driven manual before, your xB clutch and transmission may have a hard life, and adding a quick shifter will only make it worse. The only wose thing you coulld do is add a pistol grip shifter to really master the beast.
Stick with the standard shifter, and learn to use it gently. As it is, you could be immediately unhappy with the feel, and soon you could be complaining about gear grinding and clutch slip. Many here have.
I have only owned sticks, and love my xB's clutch and transmission. It is the easiest and smoothest clutch and transmission I have ever had, and I savor every shift, but very many more knowledgeable people here have pronounced the xB clutch/transmission combo to be crap.
On the other hand, everyone agrees that the xB's automatic transmission is the very best there is. It seems that anyone who has the slightest suspicion about the manual should get the automatic.
Old Jul 28, 2006 | 01:28 AM
Jhhnn's Avatar
I really like my trd shifter- it just has a better, more positive feel than the original, and eliminated any vagueness, particularly wrt second gear downshifting...
But I prefer a gearbox, and have driven them for many years. I've never owned an automatic transmission car my whole life. I do own an ancient automatic ford pickup used for occasional hauling, and wish it had a gearbox...
If you're mechanically inclined at all, and have access to tools, then you'll save the shifter installation cost with a diy... It's a little bit of a pita, particularly the spring clips, but you may never earn a higher wage in your life...
The trd clutch apparently uses the stock disk and a stronger pressure plate. Which isn't a bad thing, per se- depends on how you drive. Having it dealer installed has warranty advantages... The stock clutch seems fine for normal driving. Mine chattered occasionally when new, but seems to have worn in nicely at a lowly 2K miles...
Old Jul 28, 2006 | 02:29 PM
vintage42's Avatar
Originally Posted by Jhhnn
I really like my trd shifter- it just has a better, more positive feel than the original, and eliminated any vagueness... The stock clutch seems fine for normal driving. Mine chattered occasionally when new, but seems to have worn in nicely at a lowly 2K miles...
Before the car came I thought the TRD shifter was something I would need. Now after 5000 miles, I don't feel it is a need, but I am curious to try it and might get it when I run out of other mods to do. I installed foglights, now the cruise control has arrived, and a ScanGuage is on the way.
I felt my clutch chatter a few times during the first 1000 miles, but not in the 4000 miles since then. I guess that is from wearing in.
Old Jul 28, 2006 | 07:37 PM
EvilBox06's Avatar
Default TRD Shifter and clutch
My advice for you would be to get the shifter if you want it, but hold off on the clutch because you'll probally burn it out quick since it's your first manual. I speaking from experience. I bought an 05 Black Sand Pearl manual last year and it was my first stick, I burned the clutch out in 6 months. I then got the TRD performance clutch and the TRD short shifter and had no problems with it. Unfortunately I got rear ended and it was totaled only to get an RS3 but it's an auto. Also, look for the shifter on ebay, I got mine new for $65 including shipping. Good luck!
Old Jul 29, 2006 | 01:32 AM
Jhhnn's Avatar
My shifter came from ebay, as well- slightly used, but in the original box, etc- I really didn't like they way they dealt with the boot, so I bored out the plastic collar to fit the larger diameter shaft, taped some foamed neoprene to the shaft to hold up the collar... stock ****, looks completely factory...
Old Aug 14, 2006 | 05:10 PM
Bsbox's Avatar
GET a TWM stage 2 if anything. It is more expensive but by far the best!!!! The TRD sucks in comparison.
DJ_FroZone
25
May 30, 2019 07:17 PM
NonStopTuning
Jun 29, 2015 07:42 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
gularti
Dec 4, 2014 01:21 PM
nacy333
Oct 30, 2004 02:35 PM
