halo/led wiring question
Old Jul 27, 2006 | 01:17 PM
duston831's Avatar
Default halo/led wiring question
I spliced the wire that goes to the parking light, and twisted it around with the 4 wires from the halos/leds and put a connector on top of it. Is that ok? I mean its working, but is it going to last? Is it safe?
Also, If i get the fogs w/the halos, could i add the fog halo wire with the above wires? and just splice the lowbeams and add the foglight wires?
Old Jul 27, 2006 | 02:35 PM
Neothin's Avatar
I would really like to try and help you, but i'm confused as to what you actually spliced into where.
Old Jul 27, 2006 | 03:23 PM
warpsycho's Avatar
My Fog lights i just got last week had Halos the wires came from the fog/halos to a fuse box, to a relay, then only two wires go into the car itself. the 2 wires hooked up to the switch it came with. the switch then had a ground and a power cable. I spliced one of the brown cables for the parking light and grounded the other like normal.
I dont know if that will help you at all or not but i tried.
Old Jul 27, 2006 | 05:24 PM
duston831's Avatar
ok, theres 2 wires that run to the parking light bulb, i cut that, stripped the wires on both ends, then twisted them back together, along with 4 other wires which run to the halos and leds. everything is working fine, but is it safe and will it last?
Old Jul 27, 2006 | 05:28 PM
duston831's Avatar
so what im trying to say is that my halos and leds are running off the wire that connects to the parking light bulb (i dont have the parking light bulb in though cuz i think it looks like crap).
Old Jul 27, 2006 | 05:52 PM
dp-_-'s Avatar
take pictures
Old Jul 27, 2006 | 07:29 PM
duston831's Avatar
blah, im at work and not sure where my camera at home is......... idk how else to describe it. the 2 wires (power/ground) that run to one of the parking lights (the way it is stock) is now also powering my halos and leds on one side.
Old Jul 27, 2006 | 07:36 PM
duston831's Avatar
http://www.geocities.com/crazysk8r831/wires.bmp
PICTURE ^^^^^^^^^^^^^^
Old Jul 27, 2006 | 09:16 PM
dp-_-'s Avatar
it sounds right....i don't remember 100% but that drawing looks familiar/similar....maybe someone else can help confirm this.
Old Jul 27, 2006 | 10:05 PM
krazykustomz's Avatar
You really should be using a relay for the halos. Tapping onto the parking light wire directly is not advised.
Old Jul 27, 2006 | 11:08 PM
duston831's Avatar
so how would i go about using a relay?
Old Jul 27, 2006 | 11:15 PM
XlShadowlX's Avatar
i got mine set up pretty much same as wat u did an had them in for bout 3 months now an havent had any problems so far
Old Jul 27, 2006 | 11:30 PM
If the parking light wire is 12 volt when on this is the diagram you will need
bosch 12 volt relay
pin 8712 volt constant
pin 86 12 volt switched from parking light
pin 85 ground
pin 30 output to halos
pin 87a not used
This way the parking light circuit only energizes the relay and the relay powers the halos.
Old Jul 28, 2006 | 01:27 AM
duston831's Avatar
xlh shadow looks nice, how did you wire up the fogs?
krazy, I wouldnt mind getting that but i have no idea how to wire all that up
Old Jul 28, 2006 | 02:40 AM
1_kLEan_tC's Avatar
Too much halo effect....but if this floats your boat.....well then thats kool.
Old Jul 28, 2006 | 03:11 AM
magyver's Avatar
no need for a relay, they dont draw that much if there led.. im talking 150ma max.. which is no where close to the call for an relay.. seriouisly... thats just a waste of time and money.
no need to cut the wires though, a simple red t-tap woulda worked just fine. the red part clips over the cars wiring, then you put a male spade conector on the accesory and boom, your done.. that way you dont muck up the factory wiring.. cant hardly tell anythign was hooked up...
Old Jul 28, 2006 | 03:38 AM
XlShadowlX's Avatar
i got my fogs online an this fourm really helped alot
https://www.scionlife.com/forums/vie...highlight=halo
Old Jul 28, 2006 | 07:49 AM
dp-_-'s Avatar
ohhhhhh....you're talking about those ebay projectors/halos. I thought you were talking about demon eyes
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
vpkb
12
Oct 8, 2003 04:17 AM
