NEW!! Info About NST pulleys
Old Jul 27, 2006 | 07:57 PM
davedavetC's Avatar
Default NEW!! Info About NST pulleys
I did and i will again choose Non Stop Tuning!
heres why:
The NST Scion tC pulley kit increases horsepower via great weight reduction and the underdriving of accessories. Superior to other available kits, NST kits also offer an Overdrive Alternator Pulley to optimize output for stereo system lovers!
Each kit is carefully crafted from 6061-T6 aircraft aluminum, tested and balanced to high tolerances. Every NST pulley is hard anodized for exceptional durability and is available in a choice of colors: Blue or Graphite Gray.
BENEFITS
Great weight reduction
- Average of 65% - 70% over OEM
Increased horsepower
- Average of 7 - 10 horsepower
Lower ET's & higher trap speeds
- Average of .20s & average of 2MPH
WEIGHT COMPARISONS-_________OEM-___________-NST-
Crank Pulley_____________________59oz___________14oz
Alternator Pulley _________________10oz___________03oz
Water Pump Pulley________________14oz___________06oz
Also some notes that NST would like to point out:
1. Our underdrive specs and stats have not changed.... our underdrive pulleys NST02020 are still the same size
2. the only difference is the pulleys now have holes drilled in them for a more cosmetic look
3. this results in a little more weight reduction
also on another note:
Prices may be going up soon because the price of aluminum has steadily increased over the past couple years. So anyone interested may want to take advantage of the $99 price tag (20% Underdrive Crank) while they can.
Also a note from me
im going to make a note that i am not an employee of NST and that this is just a customers review
i hope that this was helpful and if anyone has any specific questions feel free to send NST a message on AIM: NSTonAIM :D
Check here for the NST page for ordering info
Old Jul 27, 2006 | 10:04 PM
davedavetC's Avatar
bump for an awesome product/company/customer service!
Old Jul 28, 2006 | 12:59 AM
BigPinoyTC's Avatar
Just a question but i was told that a pulley good be bad and good for a Fi car???
I have turbo would it benefit me more to get it or no??
Old Jul 28, 2006 | 01:10 AM
soros151's Avatar
Dang! When will the price go up, for I am saving for this product right now.
Old Jul 28, 2006 | 03:01 AM
davedavetC's Avatar
i dont exactly know the effects of it on a turbo car, but if the underdriven scares you they have a stock sized pulley that is just lightweight!!!
i also dont know when the price will go up. but dont expect it to go up a lot. you should be good. how long do you think it will take to save up? you should be good
Old Jul 28, 2006 | 03:16 AM
soros151's Avatar
About a month more I think, thats top.
Old Jul 28, 2006 | 03:25 AM
davedavetC's Avatar
you should be good.
its about the same for me to get the rest of my set (i have the crank right now)
Old Jul 28, 2006 | 04:22 AM
soros151's Avatar
I want to get everything in one big jump.
Old Jul 28, 2006 | 05:18 AM
Sam_J84's Avatar
go NST!
Old Jul 28, 2006 | 03:18 PM
davedavetC's Avatar
bumpity bump!
Old Aug 6, 2006 | 05:39 AM
davedavetC's Avatar
bizzump!
Old Aug 6, 2006 | 05:55 PM
Zebman's Avatar
I'm a noob to most things enginewise. How does this affect the accessories? (A/C, water pump, etc.)
Old Aug 6, 2006 | 10:50 PM
hPower's Avatar
The underdrive crank pulley slows down your accessories a little bit and sends less power to them. More power can be sent to drive your wheels as a result.
Your A/C will run a little bit slower than normal, but not so slow that it will blow hot air (anyone who tells you that your A/C will become a heater is full of it!)
You will gain more power at the wheels and your A/C will last longer because it is not working as hard.
The same as above goes for your water pump, alt, etc.
Another benefit of running the accessories a little slower is increased fuel economy. You will see better MPG if you install an underdrive crank pulley.
All NST pulleys are also lighter than the stock pulleys. Weight reduction leads to better throttle response and quicker lap times
Look for the screen name NSTonAIM if you use AIM and ask them to go into it further if you want.
Old Aug 7, 2006 | 03:11 AM
TCpete's Avatar
correct me if i am wrong but isnt changing the crank pully harmful to the engine/bearings/crank etc on the block???
Old Aug 7, 2006 | 04:33 AM
davedavetC's Avatar
you can search around for that, some say its a myth some say its true. i dont know exactly, but i believe i read somewhere that most cars wont even see any damage from it in its lifespan. someone correct me if im wrong
Old Aug 7, 2006 | 04:53 AM
3min3m2's Avatar
depends who you talk to....i have seen proof both ways, so it is possible......
personally, i will be installing a pulley before long, just a matter of time...and if something goes wrong, then i have no one to blame but myself...
Old Aug 7, 2006 | 04:54 AM
soros151's Avatar
Is there evidence to support these on our motors? Well the real answer is still to soon to see any effects, so for now let's leave the crank pulley issues out of this thread, for this thread is not about the issues with crank pulleys.
Old Aug 7, 2006 | 04:55 AM
3min3m2's Avatar
well stated...
Old Aug 15, 2006 | 02:35 AM
davedavetC's Avatar
bump for those interested in getting IMO the best pulley(s) out for the tC!!
Old Aug 15, 2006 | 02:50 AM
Kumitsu's Avatar
/Agree
