custom intakes
Old Jul 6, 2004 | 08:59 PM
supaguy's Avatar
Default custom intakes
i wanna build my own intake. but i need that one part where the mass airflow sensor connects to. any ideas on where i can find just that onepart??
Old Jul 6, 2004 | 09:23 PM
kdanie's Avatar
That is not a "part", you will have to fabricate your own. It's not really hard to do with a piece of aluminum plate, just drill the center hole from a measurement you take from your MAF sensor then drill the mounting holes and tap them, cut off the excess and your done. If your pipe is steel and not aluminum you can epoxy the piece to the pipe.
ken
Old Jul 6, 2004 | 09:42 PM
supaguy's Avatar
ah. thanks ken.
Old Jul 11, 2004 | 08:26 AM
supaguy's Avatar
i currently got the MAFS duct taped to the tube that was from the top part of the airbox. it's quite useful once you pull it out and saw off the corners.
Old Jul 11, 2004 | 06:19 PM
Guest
Guest
Posts: n/a
becareful, I made my own and the maf sensor still didn't seal correctly. Caused the check engine light to come on and had to go back to the dealer to reset it. Fabricators beware.
Old Jul 11, 2004 | 09:57 PM
supaguy's Avatar
ahh. the light didn't come on at all
even on my 6 hour drive back from LA.
but i still need to do the piping..
i wanna use steel pipes, and pull out those rubber ones.
and suggestions or advice?
Old Jul 11, 2004 | 10:14 PM
Guest
Guest
Posts: n/a
the light didn't come on until 2weeks later.
Old Jul 12, 2004 | 10:03 AM
supaguy's Avatar
did you reset the ecu???
i still need some advice on the piping...
it's weird cuz of the little tube thats in the middle of the big pipe.
bigAL
Mar 19, 2018 06:00 AM
r2photography
Jun 17, 2015 08:48 AM
xa007xa
Mar 31, 2015 09:24 PM
CONCRETETC
Feb 9, 2015 08:05 PM
carid
Feb 9, 2015 01:49 PM
