Minor Suspension problem
Old Aug 1, 2006 | 04:49 PM
dachmo's Avatar
Default Minor Suspension problem
I have the Tein SS-P and the Hotchkis Front sway Bar instaled and on full lock (left and right) of the steering wheel, the tiebars are hitting the sway bar.
Is there any way to fix this?
Does anyone know where I can get custom shortened endlinks?
Thanks for the help.
- Dante
Old Aug 2, 2006 | 01:55 PM
dachmo's Avatar
bump.......
anyone else have this issue?
Old Aug 2, 2006 | 06:03 PM
Otocan's Avatar
everyone has that issue with that setup, fact of life unless someone does a redesign.
Just don't turn full lock, it's not good for your pump anyways.
a search would've found your answer as well.
Old Aug 3, 2006 | 12:22 AM
fullforcescion's Avatar
Default custon designed adjustable endlinks
i have the tein ss-p's with front and rear hotchkis sway bars, and greddy strut tower bars front and rear. i was having the issue with my front sway bar hitting my tie rod, then a guy i know cut the endlinks, it took care of that problem,but he cut them too short. the only problem is that it is hitting something else on top of the sway bar. only when i hit bumps in the road. so i decided to make some instead, so i made some calls , asked some friends and next thing you know i can get the parts. and it is guaranteed to work.
i am making custom adjustable endlinks for the tein ss-p coilover setup, i am using all parts that are used for sprint cars so they are strong. i am using stainless steel, they can be done with iodized aluminum in 3 different color, i will be finishing up the endlinks hopefully on friday, hopefully the rest of my parts will be in.
when i am done i will post pictures of the product and let you know if they work well.
if everything goes well i will be taking orders for the adjustble endlinks.
i know how everyone feels so i am going to help everyone i can
i will be posting soon, e-mail me if you have any questions.
fullforcedesigns@hotmail.com
Old Aug 3, 2006 | 12:33 AM
dp-_-'s Avatar
it's because Tein relocated something...i forget what exactly.
No matter what, you will pretty much always have that issue unless you go as far as fullforcescion and modify the suspension further.
Hotchkis will not redesign the bar simply b/c it's based off STOCK....not some other suspension set up. The R&D would not be worth the pay off.
Old Aug 3, 2006 | 12:47 AM
Default solution
i am making adjusable endlinks on friday they will be available when they are finished and i can test them out, if you have any questions just ask
Ferretgrrl
Oct 15, 2018 02:50 AM
CapnChunk
Apr 13, 2015 04:06 PM
a_gonzy
Mar 21, 2015 02:40 AM
mischadoll
Mar 9, 2015 05:48 AM
fluxingnation
Dec 26, 2014 04:28 PM
