brake light fuses
Old Aug 6, 2006 | 12:47 PM
SCIONtific_tC's Avatar
Default brake light fuses
anyone know where the fuses are located for the rear lights (brake, tail, license) because i couldnt find them in the fuse box. anyone?
Old Aug 6, 2006 | 07:36 PM
imsonofagun's Avatar
Have you looked at the owner's manual? It should have what you need there. Also, have you checked the fuses beneath the dash? The manual tells ya where that is too :p.
Old Aug 6, 2006 | 07:43 PM
tc2nut4's Avatar
actually it tells you where the boxes are but does not designate which fuse does what... if you don't already have the manualgo to a dealership and they'll have the tech manual and can photocopy the page that designates which fuse does what, if your dealership can find it PM me later and I'll upload it for you... and on an off note HTF did you blow a fuse back there???
Old Aug 6, 2006 | 11:38 PM
Hyghgynx's Avatar
If you try and swap out the OEM bulbs for LEDs, it can happen. It happened to a buddy of mine on his SW tC. Not sure if this was what the original poster was doing. Stick your head in by the gas and brake pedals and look up. That's where the fuse is. The manual should tell you which fuse is which. I'll check mine to see what page its on...ok, mine (an '05 manual) is on p. 238.
Old Aug 7, 2006 | 02:17 AM
The plate that you have to remove to gain access to those fuses shows you where the fuse is actually located. Slot 9 for STOP and 16 for TAIL. Both are 10A low profile mini-fuses.
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
