Whats the best BPV for the tC S/C
Old Aug 8, 2006 | 03:28 PM
Jrowe's Avatar
Default Whats the best BPV for the tC S/C
Trying to see whats the best route for back pressure and such. I think i have heard that the Bosch that comes with the kit isnt that good.
Any ideas?
Old Aug 8, 2006 | 03:45 PM
Jake_tC's Avatar
Forge 007
Old Aug 8, 2006 | 03:57 PM
Jrowe's Avatar
Hey whats up. Where can you buy this from?
Old Aug 8, 2006 | 04:05 PM
Jake_tC's Avatar
hereya go... http://www.ecstuning.com/stage/edpd/...l=&engine=1.8T
Old Aug 8, 2006 | 08:18 PM
hPower's Avatar
I like the forge also
Old Aug 8, 2006 | 08:31 PM
-NEMESIS-'s Avatar
i run the stratmosphere. but the forge is adjustable from what i hear, and that is pretty cool.
Old Aug 8, 2006 | 09:48 PM
06SuperWhite_SoCal_tC's Avatar
So when people run these BPV's I hear some of them net HP gains on the Dyno...(I know only from keeping in boost the leaks from the stock BPV) But, what kind of differences are expected?
Old Aug 29, 2006 | 04:03 AM
navylife59's Avatar
I'm running the TurboXS RBV-25. Still adjusting the shims. Anything is better than stock.
Old Aug 29, 2006 | 03:05 PM
Simplyscion's Avatar
Team No Limitz
depending on the strat yours should be adjustable as well
Old Aug 29, 2006 | 03:19 PM
-NEMESIS-'s Avatar
mine is the non adjustable. Couldn't afford the fancy one from strat. =) but mine has been tested to hold up to 14lbs of boost b4 it leaks with some really fast responce.
Old Aug 29, 2006 | 06:37 PM
navylife59's Avatar
Reverse the connections and you will have a physical stop, not spring or vacuum tendency for premature boost leakage.
The vacuum port will still pull open the BPV. Be careful though cause if that vacuum line should be disconnected...... BLAM!!!.......compressor surge.
Old Aug 30, 2006 | 02:21 PM
Boosted06's Avatar
Forge 007, I have one on the way
ColonelSanders85
Dec 9, 2020 09:44 AM
Greg S
Jul 21, 2016 07:28 PM
Kanchi
Jun 29, 2015 02:42 AM
sallad
73
Feb 9, 2006 08:35 PM
