Do I need a lift to install a progess sway bar?
Do I need a lift to install a progess sway bar? Or can i get it on in my driveway? What if I stacked 3 or 4 floor jacks on top of each other? That sounds like a good idea.
no!! that sounds like a terrible idea! Jack it up and put 4 jackstands, two in the front two in the rear and go at it, if you don't have a jack and jackstands go buy them! Your car does not need to be real high off the ground to do this install, technically it doesn't at all need to be off the ground but if you're lowered you may run into issues like myself and just have to lift it totally. You do however want as much room to work as possible without lifting it off the ground if you're not lowered. Click this link to see why you should never do anything silly such as stack jacks on top of each other or work on a car without jackstands
https://www.scionlife.com/forums/vie...038&highlight=
P.S. I hope and pray to god you weren't serious about that jack stacking comment...
Originally Posted by timdubya
How much time is needed to install a sway bar? Also i know jack s*** about working on cars. Is this something I should pay to have done or should I just go at it?
I did it on a lift because I was doing my springs at the same time and I had the access to it, but it could be tackled with jacks and a pair of jackstands.
Originally Posted by tc2nut4
when you live in bum fucl< like me good like finding a shop to sell them lol... i made a set of wooden ones but lost them in the move some how... Anywho you always come across as very "short" with people... might wanna work on that
check these out. They're 66" long, and are made for lowered cars.
http://www.factoryramps.com/products...minilifts.html
LOL shoulda kept the pps outta there, but if i ever poke fun its because I truly think its a bad idea, in this case i just didn't want you or anyone helping you get hurt. Best of luck modding let me know how it goes
It'll take about an hour if this is your first time doing it.
I'm lowered on S-techs and I can go up a regular car ramp (going in reverse only)
And if you ever used that jack on top of jacks idea, you sir deserve a darwin award.
Originally Posted by hayalex6
You should always install a sway bar with weight on the suspension.
Something about it being adjusted, and tightened all the way.
Basically it's to make sure the nuts and crap are all torqued down completely.
quote from a DIY:
"be sure to load the suspension fully before tightening things down. I obviously did it on ramps (seems simpler to me), but whichever you prefer. "
quote from a DIY:
quote from a DIY:
quote from a DIY:
