N/A Power
Old Aug 9, 2006 | 05:42 PM
Enthusiast's Avatar
Default N/A Power
I am interested in What kinda power you guys think this combo would make?
K&N CAI
Xtreme Performance Ported Intake Manifold
Xtreme Performance Ported Head including a 5 angle valve job.
MMV Header and S-Pipe
Draxis (Spelling?) Cat Back (excpet not reaaly since there is no cat haha)
This is through an automatic tranny.
What about stock cams vs. aftermarket cams
Also kinda a random easy side question how many gears does a auto tC have?
Old Aug 9, 2006 | 06:40 PM
mattvs's Avatar
For an auto? It'll probably put you at about 160 on the ground, no way to tell though really. No one on this board has done anything like that with any sort of concrete proof.
You're not dealing with some huge displacement hardcore all-motor engine, so don't be expecting huge results.
And auto's have 4 gears, if I remember right.
Old Aug 9, 2006 | 08:30 PM
MJVsTC's Avatar
Aftermarket cams do not exist for the tC.
Old Aug 9, 2006 | 08:31 PM
zer0's Avatar
I dont think you want Draxas exhaust for all N/A power.. keeping the cat is going to hurt you, as well as all those bends..
Old Aug 10, 2006 | 02:15 AM
Neothin's Avatar
how exactly do you port a plastic intake manifold?
Old Aug 10, 2006 | 02:20 AM
zer0's Avatar
sandpaper...
Old Aug 10, 2006 | 04:43 AM
HP_Pirate's Avatar
autos have four gears plus torque converter lock up, giving you that overdrive for the highway. its not actually a 5th gear, it just takes the place of one.
Old Aug 10, 2006 | 01:53 PM
tc2nut4's Avatar
^^^ Someone please explain that too me I never knew about that
Old Aug 10, 2006 | 02:07 PM
DouBLeJ16's Avatar
Default Re: N/A Power
K&N CAI
With those mods I would expect:
14.9-15.3 with a manual
15.6-15.9 with an automatic
Old Aug 11, 2006 | 03:40 AM
HP_Pirate's Avatar
hope this helps. its a little confusing if you don't have much knowledge on auto trannies. but this is a great website for any kind of knowledge. I used as a secondary text book when I went through trade school.
Benefits and Weak Points
In addition to the very important job of allowing your car come to a complete stop without stalling the engine, the torque converter actually gives your car more torque when you accelerate out of a stop. Modern torque converters can multiply the torque of the engine by two to three times. This effect only happens when the engine is turning much faster than the transmission.
At higher speeds, the transmission catches up to the engine, eventually moving at almost the same speed. Ideally, though, the transmission would move at exactly the same speed as the engine, because this difference in speed wastes power. This is part of the reason why cars with automatic transmissions get worse gas mileage than cars with manual transmissions.
To counter this effect, some cars have a torque converter with a lockup clutch. When the two halves of the torque converter get up to speed, this clutch locks them together, eliminating the slippage and improving efficiency.
Old Aug 13, 2006 | 07:28 PM
njdan69's Avatar
ScionERA
^^^ Wow that was deep^^^
Old Aug 14, 2006 | 12:28 AM
crackl0vesyou's Avatar
K&N CAI
i ran a 15.2 with wat i got shouldnt it be like a big difference with the head and manifold work.?
Old Aug 14, 2006 | 12:43 AM
HP_Pirate's Avatar
I dynoed today and just off my intake and full megan racing exhaust I gianed 15.3 HP.
I live in denver CO, (5,280 + feet above sea level) so my numbers aren't as high as sea level but I put down 143 hp 141.9 FT_ILBS of torque. this was converted to the flywheel, so converting it back puts me at around 120 to the wheels. now remember I have a 20% total loss of HP at this elevation.
Old Aug 14, 2006 | 11:54 AM
DouBLeJ16's Avatar
So did you gain 15.3whp or 15.3 flywheel horsepower?
Old Aug 15, 2006 | 03:06 AM
HP_Pirate's Avatar
it shouldn't matter, the numbers should be the same, but with my calculations it would be to the fly.
That_Kid_Ju
Jun 26, 2015 10:57 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
