Having a problem with vibrations..
Old Aug 9, 2006 | 06:27 PM
jasonbegin's Avatar
Default Having a problem with vibrations..
my car was lowered, a while ago and im running 18's on it, i have the tein H techs..
i have noticed the past few weeks that the steering wheel, vibrates above 65mph, and it seems to be getting worse.. the dealer today told me to have the wheels Rebalanced. & That they could not do this for me...
now They apparently did a alignment a month or so ago, but just told me they could not get it up to balance the tires, Then how could they do a alignment? when they charged me for one? sounds shady right?
what could be causing the vibrations?
Old Aug 9, 2006 | 06:32 PM
scoobyroo2002's Avatar
I would have to say unbalanced tires. I think if the alignment was off it would pull to one side.
That's just my 2 cents.
Old Aug 9, 2006 | 06:38 PM
jasonbegin's Avatar
will getting them Balanced mess up the alignment?
and do i have to get another alignment when i put my Stock 17's back on this winter?
Old Aug 9, 2006 | 07:21 PM
nodsetse's Avatar
No, having the tires & wheels balanced won't mess up the alignment.
Going back to the 17's may or may not require realignment, it simply depends on how much it had to be changed from stock, when they aligned it for your 18's.
Old Aug 9, 2006 | 07:25 PM
NoLimitzBuilt's Avatar
Team No Limitz
yes you have a wheel out of balance. A alignment makes the car drive straight and tires wear correctly. The balance of the tires is what makes the tires roll round and not like a egg. Mine did that after I had a flat fixed and they didnt get the tire balanced on them correctly.
Old Aug 9, 2006 | 07:27 PM
jasonbegin's Avatar
k, cool Thanks alot guys,
it has been Stressing me out, thinking its something WRONG... The steering wheel never vibrated, so This was Freaking me out...
Old Aug 9, 2006 | 11:34 PM
MJVsTC's Avatar
Your dealer couldn't balance the tire!?
Old Aug 10, 2006 | 12:05 AM
AZURETCTONY's Avatar
I have the same problem but have been lazy in getting it fixed. With my stock 17's the car runs smooth, with my 18's it vibrates at higher speeds and its not the alignment which I had adjusted once I lowered and swaped in TRD shocks/struts.
Old Aug 12, 2006 | 02:15 AM
RaysSPL's Avatar
look into hubcentric spacers as well
Old Aug 12, 2006 | 11:56 AM
io333's Avatar
if balancing doesn't work, have it rebalanced somewhere else, 'cause most wheel balancers are terrible. Also, any rust on the brake rotor surface where the wheel presses along the studs has to be taken off, or the wheel won't be true. Also, if you have a broken belt in the tire (which you usually can't see), or a slight bend in the wheel (which you also can't see), there's no way to get rid of the vibration, except replacement of the tire or wheel... or both. Getting rid of vibration is a maddening journey sometimes, often I've resorted to throwing away all four tires, all four wheels, and getting brand new of both. Really. I've done it, at least 5 times. It's the only way sometimes.
Old Aug 12, 2006 | 12:05 PM
io333's Avatar
.... and even then, most tire manufactures ship their brand without checking for roundness. I know michelin checks, so when i'm buying an all new tire/wheel combo because vibration has been making me insane, i get michelins.
...and even then, sometimes the vibration is somewhere else in the drivetrain, like the axels/CVjoings or driveshaft... but you can't chase that down until you're sure it's not the wheels/tires. Or it could be motor mounts, or weird stuff you never even considered, like a looseness of a part somewhere, a warped brake rotor... MADDENING!!!!!!
Many times I've given up in disgust and gotten rid of the car.
Good luck!
Old Aug 12, 2006 | 05:46 PM
jasonbegin's Avatar
Thanks, hahahha>?
Old Aug 12, 2006 | 05:49 PM
uberscionofglendale's Avatar
i know of dealerships not wanting to work on modded cars....especially if they're lowered. on my accord, when i dropped it, and didn't get the car aligned right away, it caused the tires to wear unevenly, thus creating the same thing that you are experiencing. it freaked me out too.
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
