DIY: Antifouler Mod
Old Aug 10, 2006 | 05:19 AM
zer0's Avatar
Default DIY: Antifouler Mod
This DIY is for an EVO, but the same applies for the tC. You need to attach this to your S-PIPE not the header.
Notes before starting
- you might have space for only 1 spark plug anti-fouler, sometimes using 1 will work/sometimes not
- having an electric drill helps out tremendously , those battery operated ones dont have that much power; they will still work but will be a pain
- this may still not solve your problem of the light; a small amount of people that try this 'quick fix' still cant get the light to go off
STEP 1
-purchase 2 spark plug anti foulers at your local auto parts store
-18 mm size
-made by HELP brand / part number 42002
-HELP has also another part number 42009 and are shorter in length than the 42002, i have heard they worked , but i am not 100 percent
STEP 2
-disconnect the negative terminal on your battery. this will reset your ecu
-take one of the anti foulers and drill out its center using a 1/2 bit ,
-this will increase its hole size and allow your stock o2 sensor to fit
STEP 3
-screw the drilled spark plug anti-fouler on top of the original
-be sure to use some kind of anti-seize on the treads. in case you need to remove your fix with ease
STEP 4
-unscrew your stock o2 sensor and place your cel / ses fix in
-use anti seize on the threads
-clean your cell (by wiping it off with a paper towel)
STEP 5
-reinstall your o2 sensor
STEP 6
-reconnect your battery (your ecu is reset)
-you have just solved the problem of the 'damn light keeps coming on'
ps. its cost me 8 dollars for the pack of 2 spark plug anti-foulers
Credit: Jakeg97@EvoM.net
Old Aug 10, 2006 | 01:46 PM
tc2nut4's Avatar
hmmm guess it was a matter of time for this to become a tech so I can stop readin "how do i fix my CEL" over and over and over again lol
Old Aug 15, 2006 | 11:04 PM
pimptc's Avatar
well what can i do if it DOES come back on and the antifouler dosnt work, is there another way to fix it with out puttin the stock header back on?
Old Aug 16, 2006 | 01:05 AM
zer0's Avatar
Make sure your getting the right CEL code first. You may have messed something up during install.
Old Aug 16, 2006 | 01:45 AM
pimptc's Avatar
how do i make sure it is the right code?
Old Aug 16, 2006 | 01:48 AM
zer0's Avatar
Autozone and check the code.
Old Aug 16, 2006 | 02:21 AM
InLikeFlint's Avatar
You can get them on ebay now for like $15 bucks, alot better deal then the guys that were trying to sell them for $40. Decent price if you don't have drill, bits, vise, etc.
Old Aug 16, 2006 | 02:22 AM
MeatRocket's Avatar
i tried it all ready and didnt work . i sell scions at diehl in york and have two of my own. where did you buy the anti foulers at. i might double it on my tc.
Old Aug 16, 2006 | 02:35 AM
Just search "header o2 simulator tc" should only be one listing.
Old Aug 16, 2006 | 03:52 AM
roflitzjinno's Avatar
I LOVE IT!
Old Aug 28, 2006 | 03:32 AM
Yanki01's Avatar
just wondering if this mod is still going good for some peeps?
Old Oct 3, 2006 | 07:24 AM
Prototype_xB's Avatar
So you only need to do this to the secondary O2?
Old Oct 3, 2006 | 08:00 AM
tikbhoy's Avatar
yes, the sensor on the spipe
Old Oct 3, 2006 | 07:11 PM
KCTTC's Avatar
If you still get a check engine light with the anti foulers. Take them apart and put a piece of catalyst between them.
Old Oct 15, 2006 | 03:35 AM
samichmansTc's Avatar
Marvelous Scions
well today i put in my MMW headers and i didn't have the CEL eliminator, so i put in an Anit Fouler fix but my CEL still came on after about driving 40 miles. what can i do to fix it. the shop that put my headers in didn't disconnect the batter so.. should i do that? plz help.
Old Oct 15, 2006 | 03:52 AM
You have to disconnect the neg battery cable to reset the code. Should be good after that
Old Oct 15, 2006 | 01:46 PM
MeatRocket's Avatar
well ive had my dc headers on for about4 months now and the anti fouler didnt work.
so i had to reset it all the time but some times it would go away while driving and then come back on.but all of a sudden it went aoo and has been off 4 about 4 weeks which is great. i guess the car just got used to it.
Bmfxtreme
Aug 18, 2015 01:25 AM
A1_Fares
Regional - Pacific Mid
Jul 6, 2015 02:48 AM
Hzxhertimistick
May 20, 2015 12:14 AM
aszojsiaay
Apr 30, 2015 09:37 PM
