Gah! What a cramped engine bay :(
Old Aug 13, 2006 | 12:24 AM
mike6789k's Avatar
Default Gah! What a cramped engine bay :(
I cant find any usable gromets for power to my amp
What did you guys do about this and do you have any pictures?
Thank you!!!
Old Aug 13, 2006 | 12:28 AM
Harmonic_tC's Avatar
look a weee bit harder, i fit my 4G through on the DS. i dont have any pics but im sure someone who has some will chime in
G/L
Old Aug 13, 2006 | 12:39 AM
mike6789k's Avatar
eek, maybe I should take it to circuit city ?
Old Aug 13, 2006 | 12:41 AM
Nick06tC's Avatar
its real easy. I dont have a picture. But if you put the drivers seat back and look under the steering wheel at the firewall right above the brake pedal behind the visible steering shaft there is a grommet. It comes out to the driverside of where the intake manifold is, behind the throttle body.
Old Aug 13, 2006 | 12:42 AM
mike6789k's Avatar
Thanks ill go look
Old Aug 13, 2006 | 12:50 AM
ahh yeah thats it. real easy to get through
Old Aug 13, 2006 | 01:22 AM
DriveEuro's Avatar
There's a huge grommet above the clutch pedal. I couldn't get it opened since it had like a turtle neck type of thing on it that was taped up like crazy from the factory. I just sliced a small hole in it and ran my 4 guage through it. Then along the drivers side to the trunk.
Old Aug 13, 2006 | 03:31 AM
mike6789k's Avatar
Thanks guys, i got it, whew
However, I went out the SIDE of the gromet, so half of the wire is touching metal, is this bad?
Old Aug 13, 2006 | 03:35 AM
ProshopXB's Avatar
Yes, it could slowly cut into the power wire and blow your fuse or worse... Go through the grommet it self and save your car.
Old Aug 13, 2006 | 03:36 AM
paul34's Avatar
might want to "pad" it up with something since it might eventually cut through the wire, and well, we all know what happens when something metal contacts another metal wire when its not supposed to..
Old Aug 13, 2006 | 03:42 AM
mike6789k's Avatar
how do I go through it? the middle of it seems like its sealed off.... should i poke a hole in it?
Old Aug 13, 2006 | 03:45 AM
ProshopXB's Avatar
You can carefuly poke through it, make sure you dont stab any factory wires. If you are super careful you can cut a slit in the grommet near the side of it (factory wires are near the middle) and go through it. Nothing to hard to do, just a matter of being careful, but worth you car not possibly burning down.
Old Aug 13, 2006 | 03:59 AM
mike6789k's Avatar
well it's a fairly large gromet, I think ill cut a slit in the front, see if im okay and then poke through the back of it
Old Aug 13, 2006 | 05:39 PM
hotzie's Avatar
i just drilled a hole and ran my 0 gauge threw it.
Old Aug 14, 2006 | 02:04 AM
mike6789k's Avatar
ahhh, i cant find the outlet, there seems to be nothing behingd the throttle body
I poked objects through the gromet from inside the car, but saw NOTHING come out the other end from the hood (because I cant find the other end!!! )
any tips? thanks
Old Aug 14, 2006 | 02:16 AM
push it through further. i think the grommet is 2 layers
Old Aug 14, 2006 | 02:18 AM
mike6789k's Avatar
ok im going to do this:
take an exacto knife, tape it to the wire, and shove it through the side of the gromet (avoiding the cluster of factory wires in the middle
yay or nay?
Old Aug 14, 2006 | 02:21 AM
ProshopXB's Avatar
any tips? thanks
What did you use to poke through with?
And I beleive Harmonic_tC is correct about double layer gromet, so it will be a little harder to push through.
Old Aug 14, 2006 | 02:26 AM
ProshopXB's Avatar
yay or nay?
NAY Sorry man I have to be blunt, if you stick a razorknife through the whole gromet you will F*^@ somthing up, you dont want to do that. Cut a slit with the razor blade on the out side and inside of the gromet and use somthing (like a metal coat hanger to push through the two holes and tape the wire to it, not a knife.
Old Aug 14, 2006 | 03:41 AM
mike6789k's Avatar
yay or nay?
Well i cut a slit in the front (inside the car) with a pair of sharp scissors, it worked nicely, but now I need to get THROUGH it... anyone have a picture of it from the hood?
Maybe I should just drill a hole through that diamond above the brake and to the left???
