View Full Version : Stock offset? (did search)
Still_Debating_what_SCION
07-10-2004, 07:02 AM
Just had a couple question, already did a search... Maybe you all can help me out
What is the offset off a stock steelie?
I do know that the offset for the factory alloys are +39mm.
Reason I ask is because i would like to use the steelies with tires on my honda civic hatchback (no more meat on my tires, plan to upgrade later but need temporary for now). GSR stock alloys are +45mm, not sure what stock honda civic steelies are.
Please help from those who know.
BTW: I'm trying to keep a clean and simple look, going with the 7 spoke on the xB. :D
hahajoey
07-10-2004, 07:18 AM
u did a search?
but if u click under the wheel forum
the FIRST STICKY POST:
http://www.scionlife.com/forums/viewtopic.php?t=348
Stock Wheels/Tires
15"x5.5" +38 offset / 195/60-15
i wouldn't suggest putting +45 on ur car.
go or match the stock
JDMxB
07-10-2004, 08:52 AM
Your stock Honda steelies will not work on the Scions because of the center bore size.
The center bore of the Scions are larger than the ones found on Honda stock wheels--you can run Scion steelies on Hondas--although this will result in an unbalanced wheel. You cannot however run the smaller centerbored Honda steelie on a larger centerbored Scion.
hahajoey
07-10-2004, 09:06 AM
damn i totally forgot the center bore!
oh yea. we tried some steelies off my xb
on my friend's honda, he had to tighten and retighten the
lugs every day almost
TheScionicMan
07-10-2004, 10:08 AM
Wouldn't a hubcentric ring resolve that problem?
JDMxB
07-10-2004, 10:14 AM
Misread the original post--he wants to run scion steelies on his Honda.
Yes, I assume that hubcentric rings would work--I have not tested this, but we have tried running stock scion steelies without hubcentric rings on a friends DA Integra...not safe at all, as the wheels would move around alot, and just were not "balanced" at all.
You could try running the hubcentric rings, but it seems odd that you would run those on stock steelies.
icemilkcoffee
07-11-2004, 12:47 AM
OK guys, let's get the info straight if we're going to help this guy:
1. Scion has a center bore of 54.1mm. Honda's have a center bore of 56.1 mm. The Honda rim will go on the Scion (if you don't mind the 45mm offset). The Scion rim will NOT go on the Honda. A small hole won't fit onto a big hub. No centering ring will change that.
2. Scion's tire size is 185/60/15. I don't know why the stickied FAQ make a mistake on something something so simple.
3. All '88-' 00 4X100 honda/acura wheels have 45mm offset AFAIK. What exactly are you trying to do?
sithscripter
07-11-2004, 12:53 AM
Not only that but the stock steelies are 15x6 ... the specs in the FAQ came from a wheel mfg site and were incorrect.
07-16-2004, 06:01 PM
thanks for the reply everyone, it sounds a little dangerous and would not want to risk it. Damn!, was just worried about offsets, not even thinking of center bore size at all. :? Thanks again!
