-JoKeR-
08-15-2006, 04:47 PM
got some off of ebay and some HIDs but im tryin to figure out how to change out the headlights
View Full Version : is there a DIY for changing out the tc projectors? -JoKeR- 08-15-2006, 04:47 PM got some off of ebay and some HIDs but im tryin to figure out how to change out the headlights Papispico 08-15-2006, 04:54 PM the bulb...or the entire lens? Sniffs 08-15-2006, 05:08 PM To remove the housing itself, you have to remove the front bumper.. it's like 6-8 bolts holding it on, pretty easy to remove.. the light housing itself is held on by a few plastic screw type inserts and a few screws..after you remove it all, the whole housing just pops off.. to separate the 2 housing pieces, that's another matter.. you gotta bake them to separate the 2 pieces.... -JoKeR- 08-15-2006, 05:20 PM To remove the housing itself, you have to remove the front bumper.. it's like 6-8 bolts holding it on, pretty easy to remove.. the light housing itself is held on by a few plastic screw type inserts and a few screws..after you remove it all, the whole housing just pops off.. to separate the 2 housing pieces, that's another matter.. you gotta bake them to separate the 2 pieces.... thats all i needed to know...i can get the bumper off but i was trying to figure out how the housing was secured thanks SquallLHeart 08-15-2006, 05:26 PM take off the bumper and you should see what you need to remove. Sniffs 08-15-2006, 06:01 PM there is a clip under the headlight housing that secures it, after all the bolts are removed, you need to pull it forward then off.. what I mean by pulling it forward is pull horizontal to undo that little clip.. Neothin 08-15-2006, 07:31 PM i use a flat screwdriver to gently separate the clip so it pops out mroe easily. Sniffs 08-15-2006, 08:24 PM ^^ that works also.. probably easier too.. |
