can some one help me to find a tuning shop
ok this whats going on 1st i got the kit install 2nd its pushing 11psi 3rd i need to find a tuning shop to get my car on the righ way i just need a full tuning i heard that there are some in MD but i dont know were so can some one help me out i just want my car tune the right way
sIcKsCiOnS
DelMarVa
Scion Tuners
in MD, no.....none that i trust
since your in VA it looks like
try ProMotionTuning, speak with James. Hes great guy, his techs are awesome
www.promotiontuning.com
in VA you also have VIP Garage and PTuning but they do not have the new shops up and running yet, so not sure if the current locations have dyno tune available
www.ptuning.com
www.vipgarageonline.com
or you can always go see Howard at AR Fabrication in winchester,VA
www.arfabrication.com
www.ptuning.com
Guest
Posts: n/a
Before you spend any money on tuning, you may first want to check to see if everything is installed correctly. We have installed a few of the GReddy turbo kits on the tC, and the highest psi we have seen is around 8-9.5 psi. @ around 240+ WHP If you contact GReddy, they will tell you the same thing. This is around the default setting they have pre-set in the E-Manage. You may spike to 11 psi or so, but it should not be the normal setting.
In addition, you may want to be sure that you are running a colder plugs as recommended by GReddy. Lastly, a wideband setup will help give you an idea of how rich or lean your car is running. This is a very helpful tool for tuning.
If you see a lot of knocking, especially at wide-open throttle, highly recommend that you ease up on the boost until you can get the problem resolved. Otherwise, you may cause damage to your motor.
Our full-service facility w/ AWD dyno, in-ground alignment, etc will be fully operational around Oct-Nov 2006. However, if you need for us to road-tune the car, please contact us.
Regards,
PTUNING
www.ptuning.com
1-877-788-6464
www.ptuning.com
www.ptuning.com
i'v also read good things about Andrewtech automotive. they did a STI spec-c swap into a 03 WRX in this months modified mag
atlantic motorsports in gaithersburg. they just broke 1k hp with there evo
http://www.amstuning.com/
sIcKsCiOnS
DelMarVa
Scion Tuners
not with me, never taken a car there
but have plenty of friends that have had issues with them, and somehow
i got stuck in the middle
but ill leave them be....
Guest
Posts: n/a
AMS Tuning is the one with the 1000 WHP EVO.
Regards,
PTUNING
www.ptuning.com
1-877-788-6464
Regards,
PTUNING
www.ptuning.com
1-877-788-6464
well the reason y i wanna tune my car is not because of the psi is because like wen the car is park at the light the car feels like is going to turn off and some times it does often u can see the rpm going from 1500 to 500 and i ask around and they told me that to fix the car will be to tune it i mean i dont want more hp at the moment i just want the car to stop doing that some times on 2nd gear it will be hard for the rpm to go higher than 300 rpm and then the car start shaking so i just wasnt to fix that.
cid_mcdp
Jan 5, 2015 02:45 PM
carid
Dec 16, 2014 09:53 AM
