clutch and gear problem
Old Aug 17, 2006 | 12:30 AM
allannss's Avatar
Default clutch and gear problem
recently out of nowhere i just noticed my clutch being really really soft to the point where it took like 15mins to adjust then i noticed how easy it was to get in to gears like 5th also before i wasnt able to move the shifter into neutral without the pushing the clutch i bet it would but would require some force now itll just go in like nothing ... is it cuz im breaking it in .. just hit 5k ... sorry for the paranoid post
Old Aug 17, 2006 | 02:15 AM
Zebman's Avatar
Default Re: clutch and gear problem
You're supposed to push the clutch in regardless of if it's easy or not. Judging by your reaction, you've probably worn your clutch down excessively.
To add to my rude reply, no, it's not part of the break-in process. Pulling it out of gear without disengaging wears it down severely and can cause long-term damage.
Old Aug 17, 2006 | 02:57 AM
Spect2K3's Avatar
yea, clutch whenever moving the stick. thats the first thing I told my sister when teaching her to drive stick...have it checked at the mechanic or dealer, or whomever you use and then get a second or third opinion so that you don't get ripped off with more repair costs than you need
Old Aug 17, 2006 | 04:13 AM
allannss's Avatar
ok how bout the extremely soft clutch and wearing it down in 5k miles i nevery redline nor do i drag it but yea i mean i just found it weird that from 5th gear it goes into neutral easy so none of you experienced an extremrely soft clutch outta nowhere
Old Aug 17, 2006 | 09:13 PM
1badTc2-0's Avatar
take it in, if this is a constant problem then a tech should be able to easily diagnose the problem in an hour tops.
my guess, you need a trans fluid flush
Old Aug 18, 2006 | 01:35 AM
Zebman's Avatar
My clutch is soft too at 12k. I'm probably going to look into a performance one, since the clutch is a wear/tear item and isn't covered under warranty.
Old Aug 18, 2006 | 02:41 AM
xnevergiveinx's Avatar
from on level ground with the ebrake off, push in the clutch pedal, put it in third gear
let out the clutch pedal slowly. if the car doesn't move, your clutch needs to be replaced.
if it pulls the car, you should be ok, but i would still get it checked out
evolving_machine
Oct 21, 2023 01:16 PM
Dmmcclair
Aug 13, 2015 07:14 PM
yhwhdesign
10
Feb 6, 2015 05:00 AM
baker08tc
Dec 30, 2014 12:02 AM
gularti
Dec 4, 2014 01:21 PM
