Synthetic Power Steering Fluid
Old Aug 17, 2006 | 02:30 PM
brownbanana's Avatar
Default Synthetic Power Steering Fluid
For those who are just obsessed with using synthetic fluids in their car (such as me), has anyone tried using synthetic power steering fluid? Also, what would be the pros/cons of doing this and what would people recommend?
Im already using or soon will be switching to:
-Mobil 1 Synthetic motor oil
-Redline MT-90 Gear Oil
-Valvoline Synthetic Brake Fluid
Our owners manual suggests ATF Dexron II or III so what products would be recommend? Would products such as Redline D4 ATF or Royal Purple Max ATF be good choices or would Redline Powersteering Fluid or some other Powersteering Fluid be better than ATF?
Old Aug 28, 2006 | 10:04 AM
anyone change out their PS fluid yet?
Old Aug 28, 2006 | 03:08 PM
vintage42's Avatar
Default Re: Synthetic Power Steering Fluid
Originally Posted by brownbanana
... has anyone tried using synthetic power steering fluid?... what would be the pros/cons of doing this and what would people recommend?...
I'm using synth Pennzoil in the motor and Redline MT-90 i the transmission. It has never occured to me to use synth power steering fluid and I don't know what the benefits would be.
I used synth (DOT5) brake fluid in a car and a motorcycle for a few years. The benefit was supposed to be no moisture absorption, so no boiling and loss of firm pedal when hot. I guess that solved a problem for people who raced on 2-year-old soggy DOT3/4 fluid. But I became concerned about another reported problem with DOT5 fluid - moisture would eventually get into the system, not be absorbed, and collect as water drops in the bottom of the calipers, below the bleeder nipples, causing a rust pits. So I reverted to regular fluid and change it every two years as recommended for my humid climate.
Old Aug 31, 2006 | 05:32 AM
bB2NER's Avatar
Music City Scions
I don't see a real need for it on our application. Also unsure how the seals in the pump and rack would react to it. Maybe for something that is heavy duty but not really seeing a need for it on the toaster.
Old Aug 31, 2006 | 09:50 PM
vintage42's Avatar
Originally Posted by vintage42
...I became concerned about another reported problem with DOT5 fluid - moisture would eventually get into the system, not be absorbed, and collect as water drops in the bottom of the calipers, below the bleeder nipples, causing a rust pits.... .
Originally Posted by jethro_b
I don't see a real need for it on our application...
Is that because moisture cannot get into our brake system?
Or is because if it does, and goes to the bottom of the brake calipers, the bleeders are at the bottom so the water can be removed?
Old Sep 1, 2006 | 08:04 AM
bB2NER's Avatar
Music City Scions
I was referring to synthetic power steering fluid not dot 5 brake fluid.
I'd just use dot 4 like on my bikes and be done with it. It would take too much work to clean the system of dot 3/4 to ready the system for the dot 5 stuff.
Old Sep 1, 2006 | 11:53 AM
vintage42's Avatar
... I'd just use dot 4 like on my bikes and be done with it. It would take too much work to clean the system of dot 3/4 to ready the system for the dot 5 stuff...
I didn't do any cleaning. I just bled the DOT 3/4 out, and a year or so later bled the DOT 5 out. I don't know if DOT 3/4 and DOT 5 mix or stay separate, but I don't think the residue of one matters when changing to the other.
I was never clear on the difference between DOT 3 and 4. I read the two bottles, the difference did not seem important, and I think those two would mix.
Old Sep 1, 2006 | 08:44 PM
bB2NER's Avatar
Music City Scions
You're not supposed to mix the 3/4 with the 5 from what I've heard. The difference between the 3 and 4 is that the 4 has a higher boiling point that is why it's recommended for most motorcycles. Mostly for their hydraulic clutch slave cylinders because their proximity to the engine heat.
BTW it's safe to mix the 3 and 4 tho.
RY_TC07
Jul 18, 2017 05:18 PM
icestorm
Jun 25, 2015 05:44 PM
allaboutdabox
Mar 17, 2015 07:22 PM
