Flywheel *after* TRD SC - Any caveats?
Just what the topic says.... Any caveats to having a flywheel installed *after* the Supercharger? Has anyone done it? What's different about the install?
Team No Limitz
I did the Fidanza flywheel and clutchmasters stage 2 after the supercharger...lemme just tell you, the flywheel is amazing with the blower...quicker revs=faster spool times...add a NST lightweight crank pulley and you are really cooking
Define competent. Are you planning on doing this yourself in your driveway? It is highly advisable to let a shop with air tools and a lift perform this install. You have to remove the subframe from the car to remove the transmission. You will also need to support the supercharger and shaft assembly because the mounting bracket attaches to the transmission housing. Overall not much more complicated but not something that is recommended without a lift, other people, and air tools.
daniinpitt
Apr 4, 2015 08:07 PM
