tom0613
08-19-2006, 01:01 AM
were on th engine block does it say 2az fe just bought a motor and cant find the FE on the engine block it only says 2az and some numbers right under that were should i look fo the FE letters
View Full Version : engine code question tom0613 08-19-2006, 01:01 AM were on th engine block does it say 2az fe just bought a motor and cant find the FE on the engine block it only says 2az and some numbers right under that were should i look fo the FE letters TcPrincess 08-19-2006, 03:22 PM it doesn't say fe. tom0613 08-19-2006, 08:59 PM no were whould i look for the fe or ar all 2az the same CuRiOuSfIsH 08-20-2006, 05:07 AM dont know if it's stamped on the car, but various oil filter sites list it as 2AZ-FE TheQuietThings 08-20-2006, 05:20 AM well, youre not going to find FE, because FE is the code of the head. 2AZ is the engine code. soros151 08-20-2006, 07:07 AM it says KA24 I think, on the block. TheQuietThings 08-20-2006, 07:11 AM KA24? that was a Nissan engine used in the 1st gen. Altima, and 240SX soros151 08-20-2006, 07:31 AM I know, just look on the right side, mid-place and look at the engine block, it says something like K20 there or KA something. I don't remember what exactly said, but I know it starts with a K. :P CuRiOuSfIsH 08-20-2006, 02:44 PM are you sure youre not imagining things? :eyebrow: soros151 08-20-2006, 07:46 PM Am I? http://i47.photobucket.com/albums/f192/soros151/DSC02570.jpg and yes it does also say 2AZ on the lower part of the engine, right side, near the tranny. Beside the OEM header. http://i47.photobucket.com/albums/f192/soros151/DSC02571.jpg CuRiOuSfIsH 08-21-2006, 01:37 AM ^^^ apparently not, but K20 and KA codes are far from anything Toyota makes. tom0613 08-21-2006, 01:51 AM yea mine says k33 and 2az Xenon_tC 08-21-2006, 02:07 AM mine says this :lalala: :lalala: :lalala: :lalala: http://img205.imageshack.us/img205/3447/553xt7.th.jpg (http://img205.imageshack.us/my.php?image=553xt7.jpg) i wish :pray: :pray: :pray: :pray: HP_Pirate 08-21-2006, 03:27 AM the k code is just a casting code. it has nothing to with the engine type. and the other letters below your 2az are the serial numbers for the engine. the fe is for the head, you should find it somewhere on there. soros151 08-21-2006, 03:50 AM ^^^ apparently not, but K20 and KA codes are far from anything Toyota makes. :tap: I told ya that I knew there was K something on the engine block. I did not assure you it was neither of those. So step back. tCduck 08-25-2006, 02:57 AM Its most likely just a manufacture code for the block. But ill have to check that out, where on the motor is it. soros151 08-25-2006, 11:18 AM The first photo is from the mid section of the block at the right. The second one is at the right of the OEM header (if you still have it) a little lower. |
