lisense plate cover rattle with subs
i have some subs in my trunk and i have a lisence plate cover and since there is no holes for the bottem part of the lisence plate, the lisence plate cover makes a rattle everytime the subs are bumping,
what should i do, should i drill a hole through the bottem, thanks in advance
go to walmart, get some 1" wide, 3/8" thick self-stick weatherstrip and attach it to the back of the license plate on the bottom. This will push the bottom away from the car just enough to keep it from rattling... simple, easy fix!
Basically same idea as above-3M Double-Sided Adhesive will do the trick also. You can always cut it to size. I just did this on Wed. and now my Hatch is quiet! Didn't cost me a thing because I had the stuff lying around the house.
i just worked on mine a few minuts ago (hehee) i got some folded newspaper to make a cushion then i just put some gaff tape over it to work like a seal. i did this over a majority of the plate, and even extra padding on the two screws on top. works really well for the license plate doesnt rattle, however the hatch itself rattles like a **** stil.. ahah.. stupid subs :] and my radio door sqeaks... lol
Best solution....just did it to my 07 SW
http://www.circuitcity.com/ssm/Dynam...oductDetail.do
Dynamat License Plate backing.
Simple and most effective.
the dynomat thing didn't work for me either i already had the back of my plate covered from my old car but the frame was the source of the rattle must say the weather stripping did the trick i recommend doing both
yeah, the dynamat is just to deaden resonances. It's a mass loading dampener. The license plate doesn't just resonate, it vibrates which causes more of a rapid tapping against the body of the car instead of a slight buzzing like the interior panels might. the weather strip will absorb the vibrations and keep it away from the car body.
Ditto on the weather stripping, did it about a year ago and it is still sticking strong and no rattles, don't use use dynamat
, it will just deaden the noise that is already there, so it'll sound like a thud, instead of a tinging sound, i've tried both. Def go with the weather stripping!
https://www.scionlife.com/forums/viewtopic.php?t=87166
Originally Posted by spECIal
wat section of walmart will this weather strip be located?
