DIY-Wiring fix for the new LED Altezza Tail Lights.
This DIY is for the people who bought the new LED Altezza's Tail.
I have been told that mine is not the only one that they wired wrong.
What you will need:
Needle nose pliers (to remove wire)
Flathead Screwdriver (to strighten out the lock)
This is the OEM socket and the LED Plug for the lights
Replace Green and Black wires. It should look like this when your done. Plug it back in and test it.
If I forgot something let me know and i'll fix it
What you will need:
hey when you installed the tail lights. did you have any problems with the fuse blowing out because when i installed the tail lights my fuse keep blowing out. like one or the other if i turn on my head lights my fuse blow but when i brake it does not blow, and samething the other way. please if you could tell my what i need to do.
1...Read the top, and follow the instructions.
2...The plug can only go in one way. So check it before you plug it.
3...You WILL have to replace the fuse or fuses
im sorry but what does this fix..my friend has these and when his signal is one his blinkers blink super fast..does this fix that...if so im gunna make him fix it because it drives me friggin nuts
It fixes the Brake and Parking Lights only.... Turn signals are set still on the factory harness. If his turn signals flash at a high rate...
A) It may be he has L.E.D. turn signals
OR
B) He has a light on the turn signal out on the car.
You can check that by turning on the hazard light on your center console. If still a problem let me know. Good luck.
OR
hes running the stock bubbles and his turn signals arent going out..the weird thing is..its just the tail lights that do it i think...both tail lights do it so idk. When his hazarads are on they blink normally...i think something is F'ed on his car
