spilled a little gasoline on my car...
Old Aug 22, 2006 | 11:49 PM
paul34's Avatar
Default spilled a little gasoline on my car...
Ok, so I was attempting to pump gas, took the nozzle out of the machine, and stupidly didn't look at where I was pointing it. Looks like there was a good amount of gas left from the previous pump... anyways I spilled some over my driver's side rear panel and it then proceeded to fall a little on my tire and wheel...
At any rate I never got that pump to work so I was out of there in probably about 45 seconds. It was raining all the way home. Once I got home I hosed that area down thoroughly.
Is it a big deal? I figured that at the most it probably took off the wax... although it doesn't really seem like it. At any rate I think I'll probably be rewaxing sooner than I was thinking.
Big deal or no?
Old Aug 23, 2006 | 12:41 AM
vintage42's Avatar
Default Re: spilled a little gasoline on my car...
Originally Posted by paul34
... I spilled some over my driver's side rear panel and it then proceeded to fall a little on my tire and wheel.... Is it a big deal? I figured that at the most it probably took off the wax...
I has happened to me. Most people would forget about it. I would wash the paint and wheel with a car wash soap, the rewax the paint and put more rubber dressing on the tire.
Old Aug 23, 2006 | 12:44 AM
surfcity40's Avatar
Yep, like vintage42 wrote, it is no big deal. Clean & wax the area, but imho, skip the tire dressing.
Old Aug 23, 2006 | 04:52 AM
xnevergiveinx's Avatar
i usually hold a piece of paper towel under the gas hole (lol) to catch the gas.
it works out fine
Old Aug 23, 2006 | 04:51 PM
must_tang50's Avatar
as long as you washed it, it should be fine
Old Aug 24, 2006 | 01:32 PM
Borisimo's Avatar
Just point the pump nozzle up when moving it away from the car, that will prevent any drips.
Old Aug 27, 2006 | 05:48 AM
bB2NER's Avatar
Music City Scions
Yep, pretty much the same procedure as fueling the bikes.
Old Aug 27, 2006 | 05:49 PM
SciontCya's Avatar
Big Sky Scion
I keep a supply of things in the trunk like quick-detailer, window cleaner, etc. and microfiber towels.
I use them to immediately remove bird crap and gas spills. It will save your paint, and if you live where it's hot and sunny, it's a must.
Cheap insurance.
Scott
Old Aug 27, 2006 | 07:06 PM
paul34's Avatar
thanks guys... I'll be washing and waxing today hopefully as long as it doesn't rain once the sun gets a little less intense
yhwhdesign
Jun 11, 2021 03:34 PM
Krysune
Jan 24, 2016 06:12 AM
carid
Feb 18, 2015 09:10 AM
