View Full Version : Help in a bind (I did a search)
xBMNx
07-12-2004, 10:11 PM
I have done a search and havn't come up with the answer i need to find...so here it goes....I would like to run 17x7.5 et42.....what size tire and spacers do I need to use so these fit with a the trd shocks/spring combo? any help on these would be great thanks
brian
dinkjs
07-12-2004, 10:17 PM
You dont need a spacer....personally with a 17 inch rim I would go with a 45 series tire
xBMNx
07-12-2004, 10:20 PM
do you know how the wheels will sit tucked or flush or inbetween
plus i would like to use a 45 series tire what size would you all recommend
dinkjs
07-12-2004, 10:23 PM
with a 42 offset it will sit exactly where the stock steelie is...for the tire I would go with a 205
In terms of using spacers I believe anything smaller then a 36 offset requires a spacer and longer studs
xBMNx
07-12-2004, 10:27 PM
ok one last question if the wheels has a et of 42 and i use a 5mm spacer does the et drop to 37?or am i wrong
ncscion
07-13-2004, 08:23 AM
dude you're on point. so whats really good? you got some typical civic wheels in mind? to answer you question the lower the offset the better. 17x7.5 needs 35 rear and 40 in front with 5 mm spacer.
