View Poll Results: Would you like this car to become a scion???
Definetely !!it rocks!!!!
35.48%
Maybe....
16.13%
I dont know
6.45%
Hell Nah!!!
41.94%
Voters: 31. You may not vote on this poll
Next Scion, A Daihatsu???
Old Jul 13, 2004 | 12:49 AM
Raziemlutto1's Avatar
Default Next Scion, A Daihatsu???
I Do not know if this true, but I am just passing this along. I have a fried that lives in Hong Kong, and he read a magazine that talked about the scion. He told me that he saw Pictures of the car, said by the magazine to be the next scion coming out. And he told me it looked identical to the Daihatsu Move Custom that they sell in hong Kong, not sure if they sell it in Japan. So this might be the next scion, but not sure.
The Magazine he told me was a Hong Kong car Magazine called "Car Plus"
I saw the specs, It is much smaller than an Xb it is actually really tiny from the outside (a la mini cooper) even smaller in some dimensions , is boxy still though. I dunno where this fits in the line up though. do you even think it is allowed in the U.S.?? Is small!! and the engine as well this is definetely a k car, but my friend told me they are tuner cars in Hong Kong, and are pretty roomy inside.
COULD this be Scion xD??????
SPECS
Model Code LA-L152S-GQVZ
Overall Length (mm) 3,395 = 133.66Inch
Overall Width (mm) 1,475 = 58.07
Overall Height (mm) 1,610 = 63.36
Wheelbase (mm) 2,390 = 94.1
Tread (mm)
- Front
- Rear 1,300
1,290
Kerb Weight (Kg) 870 =1740
BACK
Engine
Code JB-DET
Type Water-cooled, In-line 4 Cylinders, 16-valve, DOHC with Turbo Charger
Displacement (cc) 659
Bore X Stroke (mm) 61.0 X 56.4
Max.Output kW (PS)/rpm 47 (64) / 6,000
Max.Torque Nm (kg-m)/rpm 100 (10.2) / 3,600
Compression Ratio 8.2 : 1
BACK
Fuel System
Type Electronic Fuel Injection (EFI)
Fuel Used Unleaded Petrol
Fuel Tank Capacity (Litres) 36
BACK
Chassis
Transmission Type 4-speed Automatic Transmission with E-shift + / - Mode
Drive System Front Wheel Drive
Suspension
- Front
- Rear MacPherson Struts with Stabilizer Bar
Trailing Arm with Torsion Beam
Brake
- Front
- Rear Ventilated Disc Brakes
Drum Brakes
Parking Brake Pedal Type
Anti-lock Braking System
Electronic Brake Force Distribution
Brake Assist System
Steering Rack & Pinion, Electronically Controlled Power Assisted
Emission
Exhaust Emission Control System with Catalytic Convertor
Fully Comply with the Emission Standard of Japanese 2000
Minimum Turning Radius (m) 4.6
Tyre & Wheel 165/55R15 Alloy Wheel
BACK
Exterior
Rear Spoiler
Side Skirt
Chromed Door Handle
Multi-reflective Headlamps
Front Fog Lamp
LED High Mount Brake Lamp
Power Adjustable and Retractable Chromed Door Mirrors
UV Cut Window Glass
Intermittent Windscreen Wiper
Rear Window Defogger
Rear Wiper and Washer
BACK
Interior
Seating Capacity (Including driver) 4
Dual SRS Airbags
Wide Bench Front Seats with Centre Armrest and Storage Box
MOMO Leather Steering Wheel with E-shift + / - Mode
Steering Column Shift
Metallic Instrument Panel Design
Automatic Climate Control Air-conditioning System and Tachometer
Power Window
Driver Side Power Window with Jam Protection
Chromed Door Inner Handle
Power Central Door Locks
All Seats with Headrests
250 mm Sliding Rear Seats
Foldable and Hide Rear Seats
Front Seatbelt with Pretentioner and Force Limiter
Adjustable Front Seatbelt Anchor
Front & Rear 3-point ELR Seatbelts
Rear Door with Child Safety Lock
Double-section Glove Box
Passenger Seat Undertray
Passenger Seatback Pocket
Door Pockets
Front Map Lamps & Rear Personal Lamp
Luggage Room Lamp
Luggage Compartment Under box
Cupholders
Fuel Lid Opener in Cabin
Rear Accessory Socket
Electronic Tuning Radio / Single Disc CD Player System with 4 Speakers
Old Jul 13, 2004 | 12:55 AM
phatboy's Avatar
I heard something about Dihatsu, or however you spell it, but I don't know if it was about this.
I like it, really I do. I think that this could be the next generation xB.
Just my $0.02.
Old Jul 13, 2004 | 12:59 AM
superjeer's Avatar
Does toyota have an agreement with Dihatsu? Have they ever sold a korean car with their badge on it before? I hope not, but anything goes now-a-days.
Old Jul 13, 2004 | 01:06 AM
Placebo's Avatar
Possibily the passo you saw
Old Jul 13, 2004 | 01:08 AM
Well, I do not think it would be the next Xb, it is much smaller than a XB, it like the Xb's size compared to the Element which is a big difference.
I think Toyota owns daihatsu, not sure thoug, i dun think they are korean cars, but not sure as well.
What engines do you think would fit in this?? it has a .650 displacement turbo which makes around 70-75 HP,
So i'm guessing a 1.3 turbo for the U.S.??? (if it even comes here) even myself showing you the news doubt that this car would make it here
Old Jul 13, 2004 | 01:11 AM
I dont think is the toyota passo, it might become a scion though, but he e-mailed me the first picture that I posted, the rest i searched through google
Old Jul 13, 2004 | 01:16 AM
Placebo's Avatar
just did a search on google and it turns out daihatsu is owned by toyota. :D
Old Jul 13, 2004 | 08:52 AM
KevinxB's Avatar
It looks good from the side and the back but all those lights on the lower part of the bumper make it look stupid from the front. Daihatsu makes much better looking cars. And they are a Japanese car company, not Korean.
I like the YRV. Would make a much better Scion. You can even get it turbocharged and with a panorama roof similar to the tC.
where have I seen those vents before?
and apparently, it comes LHD somewhere, so they wouldn't have to rengineer it from RHD to sell it here.
Old Jul 13, 2004 | 10:43 AM
fr130's Avatar
The YRV has some old school clock. :D I was thinking of the Diahatsu as well. Is that vinyl I see on the dash :?: Toyota may stick with the 1.5L for the US Market.
How about the Daihatsu Sirion? A 4-Door Mini comes in non-1NZFE K3-VE (Dynamic Variable Valve Timing) 1.0L to 1.3L engine.
http://www.daihatsu.com/catalogue/
Old Jul 28, 2004 | 06:18 AM
icemilkcoffee's Avatar
Forget the Move or the YRV.... if Toyota is going to bring a Daihatsu over, please please please God let it be the Daihatsu Max:
I want this car even more than I want the Will Cypha... how can anyone resist that wee-bulldog look?
Lots more photos of the Max here:
http://homepage2.nifty.com/ryu-neo/page003.html
http://homepage2.nifty.com/ryu-neo/page014.html
http://sky.zero.ad.jp/~zah05328/onmax/salon.html
Old Jul 28, 2004 | 11:48 PM
KevinxB's Avatar
It looks ok, but not nearly as good without the mods on that one you posted.
Old Jul 29, 2004 | 12:49 AM
The pic you posted shows the new bumper they introduced on the Max this year- it looks a lot blander than the previous bumper with the oval fog lights.
The white car I posted actually has all the factory OEM bumpers and body kit . The only aftermarket aero is the rear roof spoiler.
Old Jul 30, 2004 | 01:57 AM
KevinxB's Avatar
Well its an ok looking car, but the front of both of them looks way too abbreviated. If it had a little more front overhang it would look more proportional IMO.
Old Jul 30, 2004 | 02:29 AM
mill0048's Avatar
The Toyota Passo and Daihatsu Boon are the same car... Don't know what kind of stake Toyota has in Daihatsu, but obviously there is something going on. Maybe we'd get one of those. :?
Old Jul 30, 2004 | 02:41 AM
TokyoRaver's Avatar
That one on bags with the chrome rims and bodykit is P.I.M.P.. and it's about the same size as a mini-cooper?? I'd definitely buy one of these.
Old Aug 6, 2004 | 07:48 AM
Sandb0x407's Avatar
Default Echo similarities?
It kind of reminds me of a Toyota Echo. The fact that the front kind of dips creates the feeling that you're going down a roller coaster.....not cool. At least that's the way I felt when I test drove the Toyota Echo, I personally didn't like it.
Old Sep 8, 2004 | 04:18 AM
Back_In_Black_xA's Avatar
Toyota owns Diahatsu, Daihatsu is Japanese not Korean.
Old Sep 8, 2004 | 04:58 AM
confucious's Avatar
Looks ugly just being stock!!
Old Sep 17, 2004 | 05:37 PM
nest's Avatar
Where is the option to vote *NO* ?
I don't see what the appeal is.
A smaller xB (so you lose the useful space) designed/made by Daihatsu (might as well be Hyundai, because it's crap)
Old Sep 18, 2004 | 03:15 AM
Placebo's Avatar
the latte version of the move looks alot cooler.
