Please help with part number
Can someone tell me the part number for the two black rubber pieces on the side of the hatch...not the part with the window that lifts up but what the hatch rests on. The two black pieces are what the part on that hatch that had a rattle fix where you put two washers under them to make them fit tighter against the black rubber pieces. I know that's probably not clear enough but I couldn't find a picture of it in the tech section.
Don't know which part you are referencing:
https://www.scionlife.com/tech/parts/?group=tc05
I'd suggest you explore tech, i tried to get you to the actual part number, but I don't know which you mean based upon your desciption.
good luck
good luck
ok I was able to find a pic of it from another thread. if you look in the upper left of the pic where there is blue you will see a retangluar black piece. this is the rubber piece that the hatch rests on when closed. that is the part number i was looking for.
thanks!
thanks!
BrokenTC2
Jan 27, 2015 03:32 AM
randomsuper
Dec 5, 2014 11:14 PM
wonderworm
31
Jul 21, 2005 08:40 PM
