View Full Version : xB coilover spec. comparison
Grandpa
07-14-2004, 05:20 PM
First let me say that each of these coilovers have different damping and are specifically tuned to the springs they are using. However, as a general rule, a lower spring rate means a softer ride. Also, the numbers published by the manufacturer may not be true in the real world, such as Tein's published numbers for their rear coilover drop. As such, the numbers below are meant as a guideline and maybe be slightly different when installed.
Second, some of these numbers are from here, some are from the manufacturer's website, and some I got from calling the manufacturer. Hopefully others will find this as useful as I did.
Cusco Vacanza (translated from cusco.co.jp using ole babelfish)
Spring Rates F/R: 3.5K/3.5KFront Lowering Height: -80mmFront Height Adjustment: -65mm to -95mmRear Lowering Height: -85mmRear Height Adjustment: -65mm to -85mmComes with front camber platesAdjustable damping
HKS C-Compact (from here and from hksusa)
Spring Rates F/R: 3K/2.4KFront Lowering Height: -65mmFront Height Adjustment: -43mm to -105mmRear Lowering Height: -57mmRear Height Adjustment: -36mm to -84mmComes without camber platesNo adjustable damping
Tanabe S-OC (from tanabe-usa)
Spring Rates F/R: 5K/3KFront Lowering Height: ?Front Height Adjustment: -6.4mm to -57.1mmRear Lowering Height: ?Rear Height Adjustment: -6.4mm to -38.1mmComes with helper springComes without camber platesNo adjustable damping
Tanabe S-OC Type-II (from tanabe-usa)
Spring Rates F/R: 5K/3KFront Lowering Height: ?Front Height Adjustment: -6.4mm to -57.1mmRear Lowering Height: ?Rear Height Adjustment: -6.4mm to -38.1mmComes without helper springComes without camber platesNo adjustable damping
Tein Basic (from here)
Spring Rates F/R: 3K/3.2KFront Lowering Height: -51mmFront Height Adjustment: -41mm to -69.5mmRear Lowering Height: -46mmRear Height Adjustment: -35mm to -65.6mmComes without camber platesno adjustable damping***note: the rear will not drop to published specs - search for more info
Tein SS (from here)
Spring Rates F/R: 3K/3.2KFront Lowering Height: -51mmFront Height Adjustment: -41mm to -70mmRear Lowering Height: -46mmRear Height Adjustment: -35mm to -66mmComes without camber platesAdjustable damping***note: the rear will not drop to published specs - search for more info
I hope this helps everyone out!
-john
Wraith
07-16-2004, 04:14 AM
John you have it wrong... on the Tein basic and Tein Super Street its 3Kg in the front and 3.2 Kg in the back...
Grandpa
07-16-2004, 01:06 PM
I was wondering about that, but it's not my fault!!! Their website has the basic listed one way and the SS listed the other. I couldn't figure out which way was right, so I guessed. :oops:
I'll fix it now.
-john
