Please help?!!!! Stretching tires...Now with one done!
Old Sep 7, 2006 | 12:01 AM
MikeC's Avatar
Default Please help?!!!! Stretching tires...Now with one done!
So I bought the Sportmax wheels that are 17X9 in the rear and I am trying to fit a 225 40 17 but they will not bead up. Granted I was on an old machine. Should these fit or am I SOL? Also is there a technique to stretching tires? Thanks.
Old Sep 7, 2006 | 01:46 AM
MikeC's Avatar
Help please?!
Old Sep 7, 2006 | 02:45 AM
Ed's Avatar
Ed
Go to another tire shop,one that has a pressurized bead seater tool (basically an air tank,manual valve,and wide nozzle).
You could also try a ratcheting tie-down strap wrapped around the tire.
Old Sep 7, 2006 | 02:54 AM
MikeC's Avatar
Thanks Ed, so I don't need to buy new tires (again)? This will help me sleep a lot better tonight. I did try the tie down strap, but I was afraid I was going to punch a hole in the tire if I went too tight. Thanks again. I will take them to the shop tomorrow and let a pro do it. Thanks again.
Old Sep 7, 2006 | 03:07 AM
fsr20det's Avatar
go on you tube. there is a video of a guy getting the beads to seal with brakleen and fire......my friends actually do this alot, so i am not saying this is a experimental method, it's pretty old school.
http://www.youtube.com/watch?v=9hV6DFMXMIU
Old Sep 7, 2006 | 03:24 AM
MikeC's Avatar
That was FRIGIN' AWESOME!!!! But, was there some air already in there?
Old Sep 7, 2006 | 03:52 AM
Spider13's Avatar
Nope, not compressed air anyway. I've seen this done to mount a tire on 4x4 in the feild. Basically you cause a small explosion inside the tire. Which causes the air to expand and bead the tire.
Old Sep 7, 2006 | 03:55 AM
MikeC's Avatar
That's frigin sick! So a little brake clean and a lighter ay? I know what I am doing tommorow. Anything else I can use chemical wise?
Old Sep 7, 2006 | 03:56 AM
MyBoX's Avatar
Dude, for that size tire and wheel, just mount them and Air them up !!
Old Sep 7, 2006 | 03:57 AM
MikeC's Avatar
Oh yeah, and does that do both sides at the same time?
Old Sep 7, 2006 | 03:58 AM
MikeC's Avatar
When I tried to air them up nothing went, air just leaked out from between the tire and rim.
Old Sep 7, 2006 | 04:00 AM
t0p_sh0tta's Avatar
Anything flammable should work. Stay at a distance and move quickly. I've singed my arm hair more than once.
MyBoX's Avatar
WoW, We install 225/35-18s on sportmax 18x9.5" with out any issue but I guess, your next try is that, and yep it will do it for both side, but make sure you have the Air ready and air it up as soon as you can !!
Old Sep 7, 2006 | 04:07 AM
Ed's Avatar
Ed
I was going to mention the "explosive" method,but I don't want someone getting hurt because of some bad advice I gave.
We've done it at my job,last time someone attempted it he got a ball of flame to the face. Luckily he hurt his pride more than anything,just singed eyebrows,lashes,and bit of his hair.
And I just noticed,you might want to change the topic title. Stretched wheels? LOL
MikeC's Avatar
When I put the tire on and added air the tire did not move, maybe you guys have more pressure? Like I said at the top I was on an old machine. Does the fluid still burn inside without adding air quickley?
Old Sep 7, 2006 | 04:09 AM
MikeC's Avatar
Yeah I prob should change the title...
Old Sep 7, 2006 | 04:10 AM
Ed's Avatar
Ed
Also try inflating with an air chuck connected to a shop hose,not the chuck/hose connected to the tire mchine. Remove the tire valve core too.
Old Sep 7, 2006 | 04:12 AM
MikeC's Avatar
I've never taken the core out before...is it pretty easy?
Old Sep 7, 2006 | 04:15 AM
MikeC's Avatar
Thanks for all of the help guys, I'm going to bed for the evening. Goodnight all.
Old Sep 7, 2006 | 05:05 AM
fsr20det's Avatar
http://www.youtube.com/watch?v=ld5h2LifTz4 biyatch!
here is another video. you spray inbetween the gap of the tire and rim. good luck!
