Eibach rear camber bolts?
Old Sep 12, 2006 | 06:52 PM
Boxer_Rebellion's Avatar
Default Eibach rear camber bolts?
Hi everyone... saw on a Echo DIY site that Eibach makes rear camber bolts for our platform... is this a viable alternative to camber shims? How many degrees of camber do they offer? I'm looking for 1-2 degrees at the most... nothing crazy that will kill the tires.
I have et20 wheels and the tires rub in the back on the inner fender lip, and no one seems to do rolling around here. I'm guessing a tad of camber would fix the problem.
Any advice/thoughts appreciated
Old Sep 12, 2006 | 09:25 PM
Ed's Avatar
Ed
Any photos of these camber bolts? I'm curious how those things bolt up.
Old Sep 12, 2006 | 09:31 PM
Check this thread here...
https://www.scionlife.com/forums/vie...olts&&start=25
According to Echo_B 1.5 degrees of negative camber is possible with bolts...
Has anyone actually done it?
Old Sep 12, 2006 | 10:17 PM
Ed's Avatar
Ed
Those are for adjusting front camber.
There is an alternative. Specialty Products sells a 2-piece plastic shim for adjusting rear camber,toe,or both at the same time. Part # is 75800,there's a -1.5 to +1.5 degree adjustment range. http://www.specprod.com
Old Sep 13, 2006 | 01:43 PM
Any other thoughts?
Old Sep 13, 2006 | 08:43 PM
Ed's Avatar
Ed
The only way (bolt-on wise) you can really change rear alignment angles is by shimming. Or try longer bolts and staggered washers.
Old Sep 23, 2006 | 01:29 AM
randode's Avatar
Wagonistas
i hope you are kidding. DO NOT SHIM YOUR HUB WITH WASHERS.
Old Sep 23, 2006 | 02:19 AM
Yeah that would be sounds like a deathtrap...
Old Sep 23, 2006 | 02:56 PM
Ed's Avatar
Ed
Yes I was joking,forgot to add the smilie
Old Sep 23, 2006 | 07:36 PM
** whew **
Old Sep 24, 2006 | 02:20 PM
randode's Avatar
Wagonistas
Originally Posted by Boxer_Rebellion
** whew **
seriously! its like when my buddy's wheel was rubbing on the brake caliper, and my dad told him to space the wheel out with washers. no no no no!
scionhawaii
13
Jun 19, 2015 03:59 PM
HeyyJose
Mar 11, 2015 02:15 PM
ScionDP
Mar 1, 2015 10:57 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
