View Full Version : HELP PLEASE!!! with projector angel lights from ebay for TC
dannygenio
09-14-2006, 02:53 AM
okay... i bought these headlights a month ago and they were working fine....
but one of the angels led lights started blinking (the one on the lowbeam.) now. both sides are blinking.... I don;t know why..... is it a wiring problem cause i just taped them? or is it the led bulbs.? help me out..
CMalagise32
09-14-2006, 03:02 AM
hey, i have the same problem, except it is the little blue light in the corner that is blinking. I took it out and I am probably just going to get a new one, probably a different color too :silly: I dont know how much, or what kind of led is behind the halos, but if you check your wiring and it looks good, id go for buying a new led.
melvynray
09-14-2006, 03:03 AM
thres some new oem looking ones... those the ones u have?
http://cgi.ebay.com/ebaymotors/04-05-06-SCION-TC-CHROME-DUAL-HALO-PROJECTOR-HEADLIGHTS_W0QQitemZ290028195460QQihZ019QQcategoryZ33710QQrdZ1QQcmdZViewItem#ebayphotohosting
Noodle
09-14-2006, 03:04 AM
I would say that it is the wiring. check your wiring, make sure they are in contact with an existing wires.
dannygenio
09-14-2006, 03:07 AM
i really did nice wiring...cause first they all working fine and like 20 seconds later they start blinking... noodle..i have same kind like yours.. the headlights... how did you wire them?.. did you just wired all four wires to the parking wire?
dannygenio
09-14-2006, 03:08 AM
btw where do i get new leds that fit them....
Noodle
09-14-2006, 03:11 AM
Yeah, I actually used zip tie to lighted up the wiring though. for example, when I wire the positive wire of the LED to the positive of the parking, I used electric tape and wrap around it really tight, then I use a zip tie to keep it tight. If you let it loose, it will drop the lights. no big deal. :P
dannygenio
09-14-2006, 03:13 AM
okay i will try that tomorrow... i hope it works..cause this is really getting my nerves...
Noodle
09-14-2006, 03:14 AM
You're gonna have to bake and open your headlights to do that. I use superflux. The one they have are 3mm I believe, very small and weak. If you're opening up your headlights, replace the halo LEDs with superflux, it is really bright.
