Questions For ZPI
Old Sep 18, 2006 | 08:37 AM
itsme's Avatar
Default Questions For ZPI
since the turbo turbine is mounted under the car and all how is effected by the rain and debre that maybe on the road? wouldnt water get sucked in by the turbine? is there anything to protect the turbine from debre or puddles? has there been in problems with the kit so far in general?
p.s. sry it was just some random thought that got into my head out of the blue while i was trying to sleep
Old Sep 18, 2006 | 03:14 PM
TuningIsLife's Avatar
They are going to offer a skid plate for the turbo area.
Old Sep 18, 2006 | 05:46 PM
itsme's Avatar
ok how about the water is it going to b a problem when you go over a puddle or when it is some hard rain?
Old Sep 18, 2006 | 11:44 PM
lppro-xb's Avatar
i have the same questions + one.. what about lowered boxes? have you tested the turbo on one yet?
Old Sep 19, 2006 | 02:01 AM
milesm4's Avatar
I was wondering about how much airflow will get to the turbo and also how is the oil return line secured because if that gets caught on anything it's lights out.
Old Sep 19, 2006 | 02:19 AM
ProshopXB's Avatar
Just as a reference here is my turbo.. the oil returm comes out and almost strait up.. so there are no worries about it getting caught by anything..also it is not the lowest part on the setup, the down pipe to turbo is..
Old Sep 19, 2006 | 02:26 AM
itsme's Avatar
is it being ran with no filter?
Old Sep 19, 2006 | 02:28 AM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
...whoa!
...i'm new to the ZPI turbo...
...that looks cool...
...i want one...
Old Sep 19, 2006 | 02:35 AM
ProshopXB's Avatar
Jason that is the back side of the turbo.. the exhaust side.. we had my exhaust off at that point.
Old Sep 19, 2006 | 06:15 AM
xaalltheway's Avatar
i know it took me awhile to figure it out...... i had to go through some post to compare it but in the other flix its just an open turbine like you can put your finger in there and get it cut off open not like i would do that well maybe a carrot but yea
p.s. sry didnt realize i was under my cousin sn but yea its me Jason(itsme)
Old Sep 19, 2006 | 06:18 AM
987KEITH's Avatar
ok off topic, but is the ZPI stuff going to replace the header, or bolt after it? Will you still be able to run "stock" exhaust?
Thanks!
Keith
Old Sep 19, 2006 | 06:20 AM
from what i see i dont think it replaces the header
Old Sep 19, 2006 | 06:35 AM
WeDriveScions's Avatar
Airflow is taken through a filter higher and fed into the turbo like a standard setup (no water will get in and lots of air available where the intake is located) it's oil cooled and should still get enough air flow to keep additional cooling on track in that regard as well
Water hitting the exterior of the turbo isn't an issue at all... the pic you see it of the exhaust side of the turbo setup, with the exhaust off....so, it is a bit confusing to some... the down pipe is the part that is the lowest... so road debre and such could be an issue to consider with it... but a protective plate is discussed too...
It's just hitting the end of development and going into production... but, looks like a much better looking and from vids and links, performing option to the GReddy.
Old Sep 19, 2006 | 12:51 PM
ProshopXB's Avatar
Thanks!
Keith
You can use your exsiting header that is on the car, the down pipe of the exhaust is what gets replaced... as for the exhaust it self:
Originally Posted by ZPIracing
We will need to know the size of your exhaust at time of ordering. It will work in conjunction with any cat back or axle back on the market.
Old Sep 19, 2006 | 05:27 PM
milesm4's Avatar
What I meant about airflow is how much will be able to cool the turbo, I was just curious about how the kit will perform once it's become heat saturated.
Old Sep 19, 2006 | 05:31 PM
ProshopXB's Avatar
Well one of the reason the redesigned the turbo setup was to help with the cooling of the turbo. It gets alot more air across it underneath the car, then it would sitting in the engine bay on top of the manifold. Hope that answers your question.
Old Sep 19, 2006 | 09:09 PM
itsme's Avatar
whats on the otherside of the turbine where the air gets sucked in? does it stay open?
Old Sep 19, 2006 | 09:12 PM
ProshopXB's Avatar
No it has a cone airfilter on it like an intake would...
Old Sep 19, 2006 | 09:44 PM
itsme's Avatar
wouldnt water get sucked through if it rained? ran over a puddle etc..... sry if this is troublesome just tryin to get some clarification
Old Sep 19, 2006 | 09:45 PM
lppro-xb's Avatar
dose anybody know the distance from the lowest piont on the turbo setup to the ground is?
