uneven drop
Old Sep 18, 2006 | 08:14 PM
angkorianthug's Avatar
Default uneven drop
i just installed lowering spring for my tc, but the wheel gap on the right side (passenger) is bigger than the left side (both front and rear wheel). does this happen to anyone else? how do you fix it? what should i look for?
Old Sep 18, 2006 | 09:59 PM
kdog_1981's Avatar
this shouldn't happen!! did u install the springs?? i would take off your bad one and make sure your spring is put in right...i did mine with no problems at all....good luck!
Old Sep 18, 2006 | 11:58 PM
Hyghgynx's Avatar
What Springs did you install? After I had my TRD Springs installed, I had the same problem. It eventually went away. Now the difference is only millimeters off. Probably due to me being the only person in my tC.
Old Sep 19, 2006 | 12:07 AM
i have espelirs.. i'll wait a week more to see what happen.
Old Sep 19, 2006 | 03:31 AM
eov32885's Avatar
make sure you are parked on a lever surface, b/c the same thing happened to me....I also notice the same thing as you did, I thought something was wrong, it turned out my drive way not level.
Old Sep 20, 2006 | 08:20 AM
theblue's Avatar
never heard of that brand.
Old Sep 23, 2006 | 09:22 AM
BlkTC's Avatar
I've never heard of that brand either... Weird..
Old Sep 26, 2006 | 07:47 AM
Syr00's Avatar
me neither........... Weird......................
Old Sep 26, 2006 | 08:07 AM
sci-on's Avatar
sIcKsCiOnS
good luck on your lowering springs..where did you get that springs from? you should have invested for a more relaiable brand bro..IMO..
Old Sep 26, 2006 | 06:23 PM
i'll see what happen after alignment. i get it from a local shop, they have life time warrantee on it... so if anything still the same, i'll learn my lesson by not doing the research first
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
ScionLife Editor
Sep 24, 2015 10:50 PM
prescottn
Sep 13, 2015 09:04 PM
JZA70
Sep 12, 2015 09:37 PM
