Fitment Question
Old Sep 20, 2006 | 08:49 PM
willlangford's Avatar
Default Fitment Question
Okay, I have a dumb question on fitment, ive done reading searching etc..but i just need to SURE this will work because i have a very short window to make sure everything will work. okay i am going to be running some temp wheels for a show, 18x8 +38. I need to be able to get the wheels out as FLUSH as possible. "hella flush" if you will. i have 215/35R18's on the rims. I also need to be able to clear the rotora big brakes up front. I have some 5mm spacers sitting next to me, i dont have the car back from the body shop yet so i cant test fit and i just want to make sure it will work. i am also going to run tanabe lowering springs. thx!
Old Sep 20, 2006 | 10:54 PM
Venom_Xb's Avatar
i run 18 x 7 38mm offset with 215/35/18 and it sits almost flush. 18 x 8 38mm might be too much. 18 x 8 42mm or 40mm maybe. I could be off though. Its hard to tell...so many people are able to run crazy sizes that you wouldnt think possible in here. I have heard of people running 20's with a 2" drop with no cutting. I dont know if thats true but my local rim shop is who told me they have seen it.
Old Sep 21, 2006 | 03:36 AM
so therefore it should be HELLA FLUSH with no issues?
Old Sep 21, 2006 | 08:01 AM
bB2NER's Avatar
Music City Scions
Sounds like it should rub to me. It might work if it was sitting stock height tho.
Old Sep 21, 2006 | 02:33 PM
on the inside or what?
Old Sep 21, 2006 | 02:59 PM
stankubrick's Avatar
You can't get "Hella Flush" without rubbing (the fender). I had 17x8 +25, and i still wasn't quite flush.
FYI, the Fabuolus bB is running 18x8.5, 9.5 +18. Now that, my friend, is Hella Flush.
I think the design of the wheel will really affect how it fits with your BBK. If it's just temporary for the show, I'd just run some fat spacers (15-25mm) at the show. You'll be "Pretty Darn Flush" and should take care of you BBK as well....HTH
Old Sep 21, 2006 | 03:04 PM
oh yea i know ill rub for sure when im "HF", but i will put the spacers on when i get to the show thats easy. so ill probably need 15-25mm spacers to get them stuff out there all the way?
Old Sep 21, 2006 | 03:16 PM
Yeah, something like 25 in back and 15 up front should do the trick.
You could probably go about 5mm more depending on your tastes. Then a little bit more if you can get some negative camber.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
