emanage blue on n/a
Old Sep 29, 2006 | 02:52 AM
chrischoi's Avatar
Default emanage blue on n/a
what are your thoughts... i just have a cai and exhaust...
think that would do anything for me?
Old Sep 29, 2006 | 02:54 AM
TcPrincess's Avatar
i think you'd be better off with a s-afc. unless you get the emanage cheap of course.
Old Sep 29, 2006 | 03:17 AM
soros151's Avatar
But people have less problems with the e-manage cause they can't tune the s-afc under 4000RPMs. So I think yhea an e-manage would be sufficient with Dezods Plug and Play Harness.
Old Sep 29, 2006 | 05:10 PM
TcPrincess's Avatar
i thought you couldn't tune under 4k no matter what afc you have. is that only a problem with the S-AFC?
Old Sep 29, 2006 | 05:29 PM
soros151's Avatar
Well I have only read here that the problem is with the s-afc.
Old Oct 16, 2006 | 01:43 AM
soros151's Avatar
so no one has used an e-manage for N/A?
Old Oct 16, 2006 | 03:29 AM
jjos1's Avatar
For the gains you would see n/a (with tunning and emange) it prob would'nt be worth it, cost wise.
Old Oct 16, 2006 | 03:51 AM
soros151's Avatar
Well, to each his own. But maybe for those who would like to stay N/A, this would be a huge step.
Old Oct 16, 2006 | 12:20 PM
tcengel's Avatar
If you want to stay N/A, save for cams and headwork. Your not going to get much from the e-manage unless you get the ultimate and can adjust the RPMS.
Old Oct 16, 2006 | 09:27 PM
XD40tC's Avatar
I/H/E and good tune with emanage. A 12-15whp gain can be expected. Thats what Ive been told from tuners. Thats worth it IMO.
Old Oct 16, 2006 | 09:48 PM
soros151's Avatar
That might put you in the range of 180-185whp with a pulley also.
Old Oct 16, 2006 | 10:05 PM
InfideL's Avatar
wow thats almost in the S/C range
Old Oct 16, 2006 | 11:04 PM
senseiturtle's Avatar
With I.H.E, pulley and good tires, an N/A tC can run 14.9 or so... which is about what a stock-tune S/C will run.
The fastest documented S/C isn't even in the 13's yet, if i recall.
In your case, i'd look into CamCon instead of eManage. A little cheaper, effective, and able to be turned off when you're not racing.
eManage is more for the hardcore N/A guys or boosted applications.
Old Oct 17, 2006 | 01:42 AM
soros151's Avatar
Well, actually I can get the e-manage (blue) with S&H for $280 and the harness for about $300 or The CamCon for $330 shipped and it's harness for $250. Both get to be in the same price, and since the blue has more features, then I guess it makes the winner in my battle. So wath do you think? Worth to get it? Since both of them are at the same price for me?
Old Oct 17, 2006 | 03:17 AM
soros151's Avatar
Guys, they are selling to me a blue e-manage for $200 used, and it is from a Greddy Turbo Kit for an xB. Can I delete the info from the original map, and make my own for map for the tC?
Old Oct 17, 2006 | 03:25 AM
ProshopXB's Avatar
You should be able to change the jumper settings inside the emanage and use the support tool to create your own map...
Old Oct 17, 2006 | 03:31 AM
soros151's Avatar
Kay, so, change the setting in the turning *****, and make the appropiate air/fuel maps.
zer0's Avatar
Absolutely you can. Hit me up on AIM sometime, and Ill share some info with you.
Old Oct 17, 2006 | 03:54 AM
soros151's Avatar
What's you AIM nick?
Old Oct 17, 2006 | 03:53 PM
chrischoi's Avatar
so i'm sitting here and brian disappears on me.
