View Full Version : DIY For Brakes or not???
tc2nut4
09-30-2006, 06:43 PM
Basically in our tech section we have a front rotor install, a rear rotor install, pad installs and line installs and a bleeding guide but not everything in one... I'm getting ready to do all this in like two hours and I was wondering if anyone wanted me to do a guide for a total brake job and take pics along the way. If not no offense taken if so I'll do it sometime this weekend and post it... so vote away
brian
09-30-2006, 07:47 PM
sure! could always use some good pics to go along with an install. the DIY are usually a lot easier to follow with step by step pictures of bolts etc. it's always easier going out there knowing exactly what you're looking at/for!
Max
09-30-2006, 07:58 PM
DIYs are always welcome. PM me when done and I will put it in the tech section.
tc2nut4
09-30-2006, 08:03 PM
ok looks like I'm bustin out the digi cam lol... and I'll be sure to PM you then Max
sciontc_06
10-03-2006, 05:58 PM
pics?
tc2nut4
10-04-2006, 10:37 PM
ran into an issue when i finished the process, the breaks weren't the problem like i thought they were so i've been trying to find rides and stuff til i could take it to the dealer... i promise i'll have the DIY up when i figure out whats going on
brian
10-04-2006, 11:16 PM
what problem did you run into?
tc2nut4
10-04-2006, 11:36 PM
well imagine a sound that sounds like bare pad hitting rotor... but its not... its not the e brake backing plate, its not a seized caliper (pad wear was normal on both sides) and the kicker is this:
grinding noise only occurs AFTER I mount my wheel... im thinking it might be a wheel bearing
