Settings for TRD Rear sway
Old Oct 6, 2006 | 01:02 PM
L8u8k8e8's Avatar
Default Settings for TRD Rear sway
I think this has been covered before in a topic, but I searched and couldnt find the topic.
At any rate, what settings would you guys suggest for the bar, I also have trd springs and shocks/struts if that matters.
I remember reading sport was a better setting, but I wanted to make sure I was remembering right. Thanks
Old Oct 6, 2006 | 01:17 PM
ryno379's Avatar
I have mine on the race or track setting, and all is good. I can't see where the street setting would do much good.
Old Oct 6, 2006 | 04:17 PM
engifineer's Avatar
Race setting all the time
Old Oct 6, 2006 | 04:21 PM
tC4italy's Avatar
"I also have trd springs and shocks/struts if that matters."
I have asked this question before but no one answered. Are shocks the same thing as struts?
Old Oct 6, 2006 | 04:22 PM
JQ's Avatar
JQ
This has been covered before. Check out the post Here
As far as I am concerned, I would put it on the race setting. Inner most hole. Perfect in terms of performance. Improves the cars handling just enough. I am a daily driver and couldn't image going any other way.[/url]
Old Oct 6, 2006 | 04:46 PM
BLUEMEANIE's Avatar
Team Hamster
Track setting on a daily driver here ... and even thats a lil weak for my taste.
No, they're different but they both do the samething - dampen the spring movement.
Old Oct 6, 2006 | 04:49 PM
tC4italy's Avatar
So if you don't want yr shocks/struts to blow out when getting TRD springs should I get the entire spring, shocks and struts at the same time>?
Old Oct 6, 2006 | 05:42 PM
engifineer's Avatar
I have run trd springs on stock struts for about 19,000 miles now with no issue. The TRDs arent as agressive a change as some other springs are and should be ok on the stock struts. While used interchangeably (incorrectly) a shock and strut differ from one another. A shock dampens suspension movement like a strut. However, a strut is part of the suspension geometry and structure. For example, the strut has mounts for the spring and also serves a structural purpose for the suspension (on the front you can see this in that it affects alignment and supports the spring). If you remove a strut, you have removed part of the suspensions structural parts. If you remove a shock, you can still drive around in most cases.. but your car will feel like it is mounted on flubber :D
Old Oct 6, 2006 | 06:34 PM
ryno379's Avatar
I'm running Tein S Techs on factory shocks and struts with no problems.
Old Oct 6, 2006 | 07:53 PM
brian's Avatar
race/tracking setting, street setting you might as well have saved your money and not bought the bar at all
Old Oct 6, 2006 | 07:55 PM
Spect2K3's Avatar
^^^ agreed
Old Oct 6, 2006 | 11:47 PM
L8u8k8e8's Avatar
Alright, thanks guys, that what I thought.
I'm getting it all installed tomorrow and ill make sure it gets set right.
Old Oct 7, 2006 | 03:43 AM
brian's Avatar
not doing the install yourself?
Old Oct 8, 2006 | 02:47 AM
L8u8k8e8's Avatar
na, the dealer had all my parts cause I bought them when I bought the car cause I didnt know of the better prices I could get elsewhere, like this site; so they installed it for me.
But me in my absolute genious forgot to take the sway bar up with me for them to install
I live 2 hours away so when the guy asked if I was going to go home and get them I just laughed.
I've read its an easy install but I need some info on it.
I know where the bar is and the 4 spots that it connects, the 2 nuts on each side and where the 2 rings are on the bar.
However, is there anything special I need to make sure about, like if I put the car up on ramps is there anything special I need to know about removing any of the parts. Also, what would I use, ramps or jacks, does the rear suspension need to be non-load bearing when I take off the bar (like with jacks) or load bearing (with ramps). Thanks for any help you can give.
BTW, I'm loving the TRD springs, the drop is just enough, I didnt want to go super agressive and this fit perfectly.
Old Oct 8, 2006 | 02:53 AM
docjpv's Avatar
i installed my sway.. and started a poll on the settings way back.. it really an easy install... had it set on track..no difference in ride quality IMO
https://www.scionlife.com/forums/vie...y+street++race
Old Oct 8, 2006 | 03:02 AM
L8u8k8e8's Avatar
I knew there was someone who had made a topic about this, I read it a while ago but couldnt find it again.
Old Oct 8, 2006 | 03:03 AM
docjpv's Avatar
hehe.. yup t'was me..
Old Oct 8, 2006 | 03:23 AM
L8u8k8e8's Avatar
so anybody got an answer for the jack vs. ramp thing?
Old Oct 8, 2006 | 04:36 PM
phungy's Avatar
Race of course, no point for street. Even for daily use. I have the Progress rear sway and I have it on the stiffest setting.
Old Oct 8, 2006 | 08:10 PM
soros151's Avatar
Is the inner hole the race setting or is it the outer hole? I'm confuszed, cause I feel a little difference and I thought it was gonna be like chocolate and $h1t. But I haven't felt too much of a difference.
