Help! CEL Codes after turbo install!
Old Oct 7, 2006 | 03:15 PM
gizmo's Avatar
Default Help! CEL Codes after turbo install!
ok guys i really need some help here.
I installed a greedy turbo on mt A/T tC
After the install and tuning my CEL was on. I tried the anti-fouler trick and nothing.
So i went to auto zone and had them check it with a code scanner.. i got 5 codes.
1. P0748 - PCM has detected a short to ground, a short to battery , or an open circuit condition in the electrical for pressure control solenoid "A".
2. P0778 - PCM has detected a short to ground, a short to battery , or an open circuit condition in the electrical for pressure control solenoid "B".
3. P0983- Shift solenoid "D" control circuit high.
4. P2716 - Pressure Control Solenoid "D" performance or stuck off.
5. P2770 - Input/Turbine speed sensor "B" circuit no signal
6. P0713 - voltage signal from trans fluid temp sensor is too high for the current engine opperating conditions. (This one i took care of with the tranny cooler)
Anyone have any suggestions as to what the problem could be? Do u think it could be the emanage system? problem with another connection?
Any help is appreciated.
-Veronica
ronnie0vero@aol.com
Old Oct 7, 2006 | 04:05 PM
IceNine's Avatar
It sounds like it's DEFINITELY the e-manage wiring....
Particularly #5 (no signal).
Old Oct 7, 2006 | 04:22 PM
gizmo's Avatar
thanks man.
Old Oct 7, 2006 | 04:27 PM
Prototype_xB's Avatar
How did you have the emanage wiring done? If it was taped or sodered, then i would recommend getting a plug and play harness from Dezod.com. Some setting with the emanage will have to be adjusted, but they can sure help you!
Old Oct 7, 2006 | 04:36 PM
gizmo's Avatar
i think someone recommended that too. damn thats like $300.
Old Oct 7, 2006 | 04:40 PM
yamaha16bw's Avatar
The plug in and play harness is worth it if it gets rid of the codes.
Old Oct 7, 2006 | 04:44 PM
gizmo's Avatar
yea but i dont wanna spend $300 + install and then still have codes.. thats my prob. If i know for sure that that's my prob then hell yea i'll dish up the $. Becasue its also causing my car to hold back when i accelerate too - and i know the CEL is whats affecting that. ahh im fustrated. I guess ill have to get it anyway.
Old Oct 7, 2006 | 05:22 PM
mike6789k's Avatar
post some pics of your emange install, if everything looks okay, then maybe you shouldnt spend $300... but if we can see something horribly wrong, then you need to
Old Oct 7, 2006 | 05:31 PM
gizmo's Avatar
ok -- i think im gonna take it bk to my tuner becasue they put it in.. then if there is still problems then i guess spend the $300. i'll post pics too.
Old Oct 7, 2006 | 09:01 PM
would ya post some pics of urself too?
Old Oct 7, 2006 | 09:03 PM
WeDriveScions's Avatar
Check all your jumpers and such for the Emanage... you need to change them commonly.... The guys at ZPI or Dezod can help you ensure the emanage is set up and wired correctly... I almost definately has to do with the emanage/wiring.
gizmo's Avatar
Old Oct 7, 2006 | 09:05 PM
gizmo's Avatar
im actually going to get my buddy at auto zome to clear the CEL light for me and see if the codes some back. If the problem is still there then it is a problem, either the wiring or something. then i guess ill get the harnest. but i called my tunner and he's positive that its not the wiring, but id rather somebody else actually look at it n get another opinion.
Old Oct 7, 2006 | 09:07 PM
mike6789k's Avatar
you dont need to go to vato zone to clear the codes... just disconnected the -ve terminal on the battery
Old Oct 7, 2006 | 09:11 PM
gizmo's Avatar
i did that already.... and still there!
Old Oct 7, 2006 | 09:12 PM
gizmo's Avatar
ok im on my way to auto zone... let u know if that damn light shows up again.
Old Oct 7, 2006 | 11:02 PM
Whocares05050's Avatar
did they come back on?
Old Oct 8, 2006 | 01:29 AM
IceNine's Avatar
Let's keep this on topic, please But i'll be the first to say - she's smokin' hot The fact that she's into cars? Doubly so.
Giz, it definitely is an emanage wiring problem. That being said, you DON'T have to bang out money for a PNP harness. You *DO* need to go back to your tuner and show him the codes being thrown. They should fix what they broke in the first place in my opinion.
If all else fails, you can always head over to Ripp on Staten Island. Perry really knows his stuff. Give that nerd a calculator and a dyno, and he can do anything lol
Old Oct 8, 2006 | 04:21 AM
garyc_01's Avatar
if its not the eman. then it mite be your trans connectors not connected i dont have a turbo so i dunno if u had 2 disconect any trans connectors
good luck
Old Oct 8, 2006 | 05:52 AM
zer0's Avatar
And you still made 215whp with all those codes? Damn!
