Clutch Chatter?
Old Oct 9, 2006 | 05:18 PM
Ingenerator's Avatar
Default Clutch Chatter?
Ok I have a noise that recently developed about 1500 miles ago. I believe it's reffered to as "clutch chatter". At idle or when driving I hear this noise that sounds like birds chirping or a squeaky belt, but when I rest my foot on the clutch it goes away. Is this bad? Did I do something to cause this? Am I going to need to replace my clutch? Please help! Thanks guys! :D
Old Oct 9, 2006 | 06:40 PM
hPower's Avatar
This is usually the sign of a weak or failing clutch. Most of the time when you hear this chatter it is because the clutch disk is wearing out and getting weaker. There really isn't any danger or anything to worry about, but you need to keep in mind that your clutch is probably on it's way out and will need to think about a replacement at some point.
Old Oct 9, 2006 | 07:15 PM
superscionik's Avatar
When I hear the squeaky noises it's when I depress the clutch. Of course, I only here this when the windows are down and not much noised around. Is that my clutch wearing out too?
Old Oct 9, 2006 | 07:40 PM
Whocares05050's Avatar
Ive heard that smae damn squek since i bought my car. theres a little spring behind the clutch pedal. i think its that.
Old Oct 10, 2006 | 03:40 AM
Ok, so I prob. still have some time before it goes so I can research a good clutch/flywheel combo. Any suggestions?
Old Oct 10, 2006 | 04:31 AM
trialsindude's Avatar
Strictly Scionized
No clutch chatter is cause by "hotspots on the flywheel itself when you engage the clutch ie. letting the clutch out. You will feel the feed back in the peddle itself.
"IF" you are hearing a noise whatever it is, and you press on the clutch slightly and it goes away, it could probably be the throw out bearing.
Old Oct 10, 2006 | 05:56 AM
Prototype_xB's Avatar
Sounds like the throw out bearing is bad. Being that it goes away when you step on the clutch, pretty much narrows it down to that. Clutch Chatter refers to how it engages. Usually shutter, excess vibration, etc is refered to as chatter.
Old Oct 10, 2006 | 06:46 PM
It does sound like a spring squeaking noise. Maybe you're right.
Old Oct 11, 2006 | 02:19 AM
Is this bad? Do I need to worry about having to replace the clutch soon? Did I cause this?
a23r
Feb 1, 2016 04:05 AM
ericr64
Nov 14, 2015 04:52 PM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
