custom CAI.....what problems might I run into
Old Oct 9, 2006 | 06:36 PM
chubster41's Avatar
Default custom CAI.....what problems might I run into
Ok well Ive was thinking...what if someone made a custom intake on there own....what problems might u run into?
would it matter where I would locate the MAF?
would 3" piping be too big?
not sure what sizes the Injen and all use
any feedback would be greatly appreciated
Old Oct 9, 2006 | 06:37 PM
citizen01's Avatar
What are you trying to accomplish? More power or less cost? or both?
Old Oct 9, 2006 | 06:40 PM
SO-CAL_TC's Avatar
The diameter of the pipe must stay the same where the MAF is curently located. It also can not be too close to the air filter or else it will receive in accurate readings.
Old Oct 9, 2006 | 06:49 PM
chubster41's Avatar
well u got me I didnt wanna say anything till I got more answers but I got sponsored by this company called Spectre Performance.......and b4 I go on its not like those carsponsorships.com things
anyways they have a intake system thing goin were u can mock up your own custom intake and when u mock it up....u tell them what pipes u want and what angles and such...
I installed it and it worked fine but got a CEL and the car kinda booged a bit. I would be on the freeway and I would floor it and it wouldnt speed up...It would take forever.....thats when I had each pipe connected by one of these
I got tired of seeing it with those so I ordered some chrome connectors
so I put the intake together but ran into a problem....when I tried to start the car it wouldnt turn on...it would turn on then die....I tried to keep it on by pressing the gas but no good just shut off......
I dont know if maybe with those new connectors I didnt tighten them down all the way or what but Im confused.....
heres the website of the company that spponsored me
http://www.powerflowracing.com/spectre-products.asp
FYI...I believe her sc is Kathryn but she has a RS1 ( i think ) well she works with them and shes the one who's helping me
Old Oct 9, 2006 | 06:55 PM
tCizzler's Avatar
Not sure if its the same situation, but on my car, i put the airbox back on for a day just to compare the two and i guess i didn't tighten the clamp around the throttle body tight enough and it came loose the same thing happened the car just died. So maybe its loose around the throttle body, or also i believe the maf sensor relies on air flow to let the car run, and if the pipe is TOO big it might not be getting enough airflow at the sensor, but those are just suggestions, not really sure.
Old Oct 9, 2006 | 06:57 PM
chubster41's Avatar
hhmmm those could be possibilities tho.....can someone tell me what size the intake out there are? I will search but just incase someone knows off the top of there head
Old Oct 9, 2006 | 07:01 PM
BOXMAN's Avatar
I belive it is 2.5" and 2.25" at the maf. I am not 100% sure
Old Oct 9, 2006 | 07:06 PM
XD40tC's Avatar
So where are you locating the MAF?
Old Oct 9, 2006 | 07:10 PM
chubster41's Avatar
Its located about 4 inches from the air filter
I will take pics tonite if I remember, I have the car back at stock now
Old Oct 10, 2006 | 12:13 AM
soros151's Avatar
2.75"
Old Oct 10, 2006 | 12:21 AM
chubster41's Avatar
so since it 2.75" would the extra .25" make a difference?
cuz the piping I have is 3"
Old Oct 10, 2006 | 12:50 AM
soros151's Avatar
Do u have the Injen? of is it "generic"?
Old Oct 10, 2006 | 12:53 AM
chubster41's Avatar
read my first post.....the piping I get is 3"
is a make it yourself custom Intake
Old Oct 10, 2006 | 12:55 AM
gcxandy's Avatar
i run spectre piping on my intake and i have no problems at all.
Old Oct 10, 2006 | 12:56 AM
soros151's Avatar
Oh, I'm sorry, didn't know that was u. Yhea I read the first post, just didn't look at the nick. I would stay in 2.75", yes .25 does the difference, if it is too big, the air will move to slowly, and it will play a lot of tricks with the MAF. Try 2.75" Unless it is not mandrel bent. If is not, then MAYBE u can experiment with the most straight foward setup with 3" pipe diameter.
Old Oct 10, 2006 | 03:25 AM
Kenshin's Avatar
READ HERE FOR THE SOLUTION TO YOUR PROBLEM!!!
You have the MAF on backwards, it is not bi directional. I did the same thing, and after banging my head for hours that was the solution LOL. I had installed the MAF on backwards, so the car would not stay on whatsoever.
Old Oct 10, 2006 | 03:38 AM
Shifty's Avatar
I have that done to my intake system. It's not a full CAI though, I only did it from the airbox to the TB. Credit for this mode goes to Doc I.
It's called the G.F.I. if you do it the way I did. (ghetto fabulous intake)
Check it out on the www.yoursciontc.com forums. That's where I learned about it. I have no pictures of mine though and I'm to lazy to do it tonight.
Here's a pic of basically exactly what mine is, except I spray painted it black.
Credit goes to "thecybe" on yoursciontc forums, it's his picture.
daniinpitt
Apr 4, 2015 08:07 PM
CONCRETETC
Feb 9, 2015 08:05 PM
cid_mcdp
Jan 5, 2015 02:45 PM
hotroddelux
Dec 3, 2014 11:33 PM
Docofmind
Nov 11, 2003 07:09 PM
