View Full Version : How do I remove the lower steering column housing?
thinkCooper
07-23-2004, 05:34 PM
I installed a cruise control earlier this week, but wasn't able to get the controller's retaining nut tight enough on the inside of the steering column lower housing. Can someone tell me if I need to remove the steering wheel to fully remove the housing? If so, could you tell where the screws are?
Cheers!
thinkCooper
07-24-2004, 06:36 PM
Answered my own question this morning. 8)
Turns out that removing the lower steering column cover is really easy. There are 3 screws. One is below the steering wheel, and easily accessable with a phillips head screwdriver. The other 2 screws face the driver, on the left and right sides of the cover but are hidden by the back of the steering wheel. These 2 screws are accessable by turning the steering wheel to either side. The wheel has a flattened area that when turned allows access to the screws. :idea:
Once the 3 screws are removed, the lower steeering column is easily pried away from the upper cover.
I needed a little time to check out the steering wheel to solve my puzzle. No need to remove the steering wheel! That's it! :mrgreen:
Cheers,
Cooper
